Question about Vehicle Parts & Accessories
12V Doesn't work Saturn SC
I have a 1998 Saturn SC1 and my 12 volt (Lighter jack) doesn't work. I need to get a phone charger/GPS and whatnot but I can't do anything without the jack giving out power. I checked my fuse box under the hood, and that doesn't work. Does anybody know where the fuse box on the inside of the car would be so I can check that? Or if you have any other ideas.. That would be great.
The interior fuse box is hidden really well. It's located on the center console (just in front of your cup holders) on the passenger side of the car. Just grab the little square box thing with your fingers and pull it to the left. It should come off pretty easily. The cover (what you pulled off) will have a diagram of what each fuse is for, and even a fuse puller for easy access.
Posted on May 19, 2009
Rangerover sport 2006 56 Reg cigarette lighter doesn’t work
look in lighter hole if there is no clips on the side. this is phone jack not a lighter jack.
Feb 01, 2018 | Land Rover Range Rover Sport Cars & Trucks
Garmin nuvi 745
Yes, a Cellphone, Google Maps and a Power Block will give you about 5 days use!
You could also carry a small 12 volt lithium battery of the type used in alarms in a back pack, connected to a cigar lighter like this unit.
12VOLT RECHARGEABLE PORTABLE BATTERY POWER PACK 12V DC CHARGER LIGHTER...
Or this
Lightweight 12 volt portable battery station Lithium ion 8 8 Amp Hours...
Or you buy a GPS Sat Nave unit specially made for cycles.
Cycling GPS Units Amazon co uk
Garmin Edge 1030
Garmin Edge 1030 GPS black 2018 handheld colour gps
Nov 18, 2017 | GPS
Cigarette lighter in car
The lighter in a Chevy Lumina can get lost easily if you routinely pull it from the socket to plug in electronic devices like GPS systems, cell phone chargers and laptops. If so, you need to replace it.
Jun 05, 2013 | Cars & Trucks
Penny dropped into the cigarette lighter of my 2008 saturn astra. I got the penny out, but the cigarette lighter doesn't work
hi,
there must have been a weak connection somewhere in the line.
use a volt meter to trace from the lighter to the fuse box.
I have also seen the wire connection go bad during a short in the back of the fuse box itself where the wire goes in.
follow the 12 volts and you will find your problem.
chris...
Sep 26, 2012 | 2008 Saturn Astra XE
Wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
2008 Road King FLHRS 12 volt adapter plug into factory plug on bike, when plugging in phone charger I get bus error and no power to phone, checked with multimeter, have power to 12v socket, caused bike to...
Hi Dan51, you might want to check with your local service department on this one, for more information on your question please visit the websites below and good luck:
Charger doesn stay put in cigarette lighter outlet
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 10, 2012 | 2004 Harley Davidson FLHRS - FLHRSI Road...
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
I Have A Nikon Coolpix s210 Camera And Everytime I Plug It In To Charge With The Wall Charger It Doesn't Work..But I Don't Have The Separate Battery Charger.Any Ideas Why This Happens?
HiIn order to check quick, you might need extra battery. In your neighbor some who has multimeter you get help from them. Or your local repair shop could help you easily.
Jun 02, 2011 | Nikon Cameras
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
Recharge
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Dec 25, 2007 | Garmin StreetPilot c550 GPS Receiver
Vehicle Parts & Accessories Logo
101 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
