Question about Husqvarna Garden
My husqvarna zr5424 mower blades wont engage after i pul up the switch
The blades will not engage when I pull the switch up.
  • 86 Answers
SOURCE: blades will not engage when you pull up on the button
When you pull switch to turn on blades do you here a click sound ? If so clutch is most likely ok,did you check your belt to make sure its ok ?Seat switch is just a saftey feature it cuts all power to the clutch so thats why blades turn off,thats why I asked you if you here a click when pulling switch that will tell you if there is power to switch.there is also most likely a fuse in the line that goes from the clutch switch to clutch.
Posted on May 12, 2009
  • 4 Answers
SOURCE: dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
Posted on May 18, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
When I engage the mower, the blades spin just fine but there isn't the same mower sound. The mower sounds exactly the same when engaged and not engaged.
If the blades are not installed correctly they wont cause the desired airflow and you wont hear the difference.
Apr 22, 2016 | Garden
The mower blades are engaged at all times. The switch that disengages blades does not work. A safety issue exists. What can you advise?
Sounds like the switch is defective and must be replaced..in the meantime...locate the wire connecting to the electric clutch fro the bad switch, shut the mower off and disconnect the wire from the clutch..you can operate the mower when not using the blades....just remember make sure you shut it down before attempting to pull the wire off the clutch..this is only a Temporary fix...good luck..
Jul 28, 2015 | Husqvarna YT48XLS 48 inch 24 HP Kawasaki...
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Bladesdoturnwhenengaged
your belt has most likely jumped out of it's intended route, or has broken, check with engine NOT running keys out switch off, pull engage knob and try to manually move blades if they move while knob is engaged, belt is broken or off track
Mar 21, 2014 | Husqvarna Garden
Blades wont ingage
I would check the belt, the pulleys and the tension of the pulleys. Any of these could be the cause of your issue. Hope this helps!
Jun 08, 2012 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
MOWER WILL NOT ENGAGE
check the fuse then see if theres power to the clutch is there a bad safety switch does the mower shut off if you get off the seat when the blades are turned on(that will test one of the safety switches)
May 04, 2012 | Husqvarna LGT25K54 Garden Tractor
Engine cuts out immediately when blades are engaged - new mower
Check the seat switch. If it is loose/out of adjustment, the mower will die when the blade is engaged. The logic of the mower requires the operator to be present (on the seat) for the blades to engage, or for the mower to move. All of the safety switches are dependent on the seat switch. Dirty connections at the switch, or the switch being out of position is the likely culprit.
Best regards, --W/D--
Jun 04, 2011 | Husqvarna Garden
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
