Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No water, no ice, but new water filter cartridge
Ge profile side by side. Just changed water filter. No ice and no water dispensed.
  • GE Master
  • 4,654 Answers
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
Posted on May 19, 2009
GE side by side water dispenser not working very well.
you need to change the filter, located in upper right hand corner of fresh food section. Order it at geappliannce.com
Oct 10, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Replaced the water filter. the refrigerator is making ice but not dispensing water
Is there any packaging from the new water filter restricting the flow. Check for anything blocking the water flow near where you replace the filter and check for correct installation. If this problem was the reason you replace the filter check the switch that dispenses the water. Make sure it isn't "iced up".
Sep 30, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Oct 12, 2009 | GE Profile Performance 25.2 cu. ft....
Moldy taste from water/ice for GE profile
What kind of external filter did you use ? If you used an $11.00 cut the line and attach on each end of the tube filter , this will not work . Go to home depot and invest in the $50.00 filter which mounts to the wall , where you replace the inner certridge by untwisting with your hand . This filter has replaceable charcoal , calcium , lime ,etc cartridges . You may have to try different cartridges to find the one your happy with .
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The water will not come out of the door. The ice will work though.
My GE Profile has a system water filter. The manual said that if the filter clogs--it will not allow water to pass thru--any ice already made will still dispense but no new ice will be made. If you have a filter and it is over 9-10 months old, it could be clogged.
Jul 04, 2009 | GE Profile PSS26NGS Side by Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
251 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
