Question about Canon imageCLASS® MF4150 All-In-One Laser Printer
Canon mf4150 - Cannot cancel a print job
Seems to be impossible to cancel a print job
on the mf4150 multifunction.
I've tried to press the "C" and "stop" and other
things without success.
Please Help
Hello, I know you wrote this seven months ago, but if you are still having issue, you have to press the "system Monitor" button on the printer. then press ok for print jobs, then the right and left arrors to cancel
It is aggrivating how canon put no shortcut button on the printer to cancel this.
It is under chapter 3 in teh advanced guide you can get at the link below on canon's site.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4150#BrochuresAndManuals
nice day.
Posted on Jan 03, 2011
  • js3391 Jan 03, 2011
    also, you may have to clear out your print queue on your computer if the jobs are stored in memory there. if they make it to the printer and or stored in its memory, then the above method should work or turn off printer will delete job in printer memory as well - that is what I did untl I read manual.
    You can practice by printing something with no paper in the printer.
Xerox workcentre 5775 I sent a 1-page document to
All you need to do is uninstall your printer to remove everything and then try re-installing again because otherwise it may be difficult for you to cancel all jobs at once.
Oct 02, 2013 | Canon imageCLASS® MF4150 All-In-One Laser...
I have lost the installation disc for mf4150
You can download the drivers to your computer and then install your software, direct from Canon.
Visit Canon Download Center , choose your country, select multifunctionals on products, select i-SENSYS MF4150 on model and press GO.
A new screen appears with all the softwares available. The search machine with operating system and language selections can be very helpfull, to find easy the softwares that'll work for you.
For the U.S. visit Canon Support and Drivers HERE .
Feb 20, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
Printer will not switch on. stuck on standby
STEP 1
Remove any other pending print jobs in the printers que until you are left with just the problem ones. Just click on each print job and choose cancel!
If a print job in the que shows "deleting" but never completes the command;
  • Go to Start then choose Run
  • Type " net stop spooler " and press Enter
  • Wait for the DOS window to open then close.
  • Go to Start then Run & type "net start spooler" press Enter
If this does not work Go To Step2
STEP 2
If that does not cancel the print job:
Your Windows XP spool directory is located at
C:\WINDOWS\SYSTEM32\SPOOL\PRINTERS
On a Windows 2000 machine the path is usually
C:\WINNT\SYSTEM32\SPOOL\PRINTERS
It will Usually will contain files looking like these:
FP00008
FP00008.SHD
There will be two files for each remaining print job. Just delete these and reboot your computer. Your print queue should now be cleared.
*** To delete the print files type " del *.* " in the correct directory and press Enter. * Make sure you are in the right path i.e., C:\WINDOWS\SYSTEM32\SPOOL\PRINTERS
If that does not work Go To Step3
If you are printing over the network, and cannot get the print job to clear the que after the above steps:
Go to the computer that has the shared printer attached and perform Steps 1 & 2 above.
If that does not work then go to the computer where the Print Job was sent from and perform steps 1 & 2 on that computer.
If everything above did not work then try this...
Step 3
If all of this does not work then run a disk check on the computer that has the printer attached
  • Type " CMD " and press Enter
  • Wait for the DOS window to open.
  • Type " CHKDSK C: /R /F " if C:\ is where your OS is installed!
  • Answer Y for yes and press enter
  • Reboot your computer and wait for the Disk Check to complete
Apr 21, 2012 | Canon Pixma MP480 All-In-One InkJet...
Won't print it always says document in queue
This sometimes happens if a print job freezes before, or during the print. I would suggest two things. Open up your print que, which you should be able to access from the bottom right hand side of your screen in your task bar. Right click, and open print que. If there is a print job in the que that says printing, try to right click on the job and cancel it. If this does not work and you have not done so already, restart your computer and your printer! Go back into the que if you have to and if the job is still there, right click and cancel job again. Then, retry printing a something different from your printer. This should solve your problem.
Sep 20, 2011 | Canon Pixma MX420 All-In-One Printer
Printer has started to print 70 pages and I need to cancel it.
Click Start - Printers and Faxes - Double Click on the Canon printer - Click on print document you wish to cancel then click on the Document at the top next to Printer and View then click on Cancel.
Feb 07, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
I would like your advice as to how to stop a Printing job before completion on Canon LBP2900B I have been wasting A4 paper because the full job has to run its course even though I wish the job to...
when printing, you may press the CANCEL button on the printer, right-click the printer tray icon and click view print jobs, then cancel a print job before it completes. you may also want to try specifying only the pages you want to be printed instead of selecting all pages to avoid unnecessary print outs. hope this helps and let us know how it goes.
Dec 04, 2010 | Canon CFX-L4500 IF Laser Printer
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
Apr 18, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Problem with Canon I-SENSYS MF 4150
After several days of researching the same problem for the MF4150, the conclusion is that you have to use an Axis or Silex brand print server developed specifically for Canon. Both have been reported to provide Print/Scan/Fax multi-functionality, but it seems Silex is the one Canon really supports (it's only sold on their website) and is most likely to be the least problematic.
Jan 05, 2007 | Edimax PS-1205UWg (PS1205UWG) Print Server
Canon imageCLASS® MF4150 All-In-One Laser Printer Logo
1,118 people viewed this question
old marine
old marine
