Question about Miele Dishwashers
How to install upper spray arm of miele G880 SC-1 dishwasher
How to install upper spray arm. I have locking nut, seal, spray arm, and nut for spray arm
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
  • 423 Answers
SOURCE: Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Posted on Apr 01, 2009
  • 423 Answers
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
Posted on May 14, 2009
  • 122 Answers
SOURCE: outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Posted on Sep 23, 2009
SOURCE: middle wash arm doesn't turn on quiet power 1 ge dishwasher
The last two holes (the ones wich give the spin to the arm) are blocked. Remove the arm and try to unblock with a thootpick and by running water into the arm.
Good luck
Posted on Aug 07, 2010
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Upper spray arm not working
I had the same problem with mine, where the water comes in at the back inside of the machine there is a big plastic nut. When i took this off, there was a broken seal. I have replaced this seal and it worked again for about a week. Now the bottom and top arms arent working. Looking at these forums it may be the circulation pump that has something blocking it but am now trying to find information on where this is and how to check it!
Sep 16, 2012 | Hotpoint 24 in. FDW60 Free-standing...
My Miele dishwasher is about 16 months old. Initially it was awesome. Now it doesn't get anything truly clean on any rack. Every item has scum and traces of food or drink left on it. I've cleaned the...
Hi bjw.... clean the dishwasher by putting 2 cups of vinegar into an empty dishwasher and running the longest and hottest cycle.
Repeat this washing as needed but generally at least once a month. Joe
Thanks for choosing Fixya!
Feb 27, 2011 | Miele G880 Dishwasher
Miele dishwasher finishes the cycle with water in the bottom and the dishes not clean
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
Nov 19, 2010 | Miele G880 Dishwasher
Miele G 880 SC -- dishes not drying
Make sure you are using rinse aid. even if you are using tablets which has rinse aid built into the tablets Miele still recommend using rinse aid liquid as well.
Make sure you have the rinse aid setting on 3ml
Plastic will not dry as well as plates as it doesn't hold the heat.
You could call out a Miele service tech if it is still under warranty and he would be able to increase the drying time through his computer.
Hope this helps.
Mar 20, 2010 | Miele G880 Dishwasher
Miele G880 dishwasher, stuck in "Top Solo" mode.
If the unit is really stuck in 'top solo' then the most likely culprit is the top solo solenoid valve located off to the side of the circulation pump. It's most likely jammed in the engaged position. You will have to uninstall the dishwasher, lay it on its left side and remove the bottom panel to access it.
Feb 13, 2010 | Miele G880 Dishwasher
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Upper arm dose not spin
have you checked to see if the arm spins freely if you push it
Apr 13, 2009 | Beko 24 in. D3421F Free-standing...
Dishwasher full of water at end of cycle
OK,,,,,,,,,,,seems to be the pump impellars or either clogged with grease ect. Find the pump amd remove the cover to it that you can have access to the inner impellar. I have seen this problem before and found that this was the problem , I hope this is yours. Goood luck RC
Oct 13, 2008 | Miele G880 Dishwasher
Upper dishwasher arm not spraying water
Have you looked at the spray arm fixing nut at the back top arm as this has just gone on my machine
Sep 27, 2008 | Dishwashers
Dishwashers Logo
60 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
