Question about Viking VCWB300R Wine Cooler
Viking wine cooler light not working
How to know if I need to replace light tube
2 Suggested Answers
  • 5370 Answers
SOURCE: My Viking VUWC140 wine cooler
Before replacing any part, first try manual defrost procedure. Unplug the wine cooler for approx 4 hours non stop.This will defrost all ice manually and this resets the internal defrost board and its assembly parts.Then after 24 hours reconnect the units power cord and turn it on, set it to normal temperature.It will take approx 6 hours get it normal cooling cycle.Then check, if its still building up ice, then it can be faulty defrost thermostat or faulty defrost main board.By pass the thermostat terminals by connecting a jumper wire.Connect two terminals of thermostat together and then see if its still building ice inside.If yes then board needs to be replaced.The thermostat located near the coils.Its a thin, twin wire connector, connected near coils.---------- This will help.Thanks.Helpmech.
Posted on Jun 20, 2011
Door seal for a viking beverage center/wine cooler VUWC140
What did you need to know? If it fell out it just pushes back in. Press it in with your thumbs. If you want to replace it its very easy to change. Just pull out the old one and put the new one against the door and push it back into the tracks.
Sep 20, 2016 | Viking Refrigerators
My wine cooler door swicht is not working,light is on even with the door closed
The switch is bad. Two wire simple switch. Replace it. Un-plug before replacing.
May 05, 2014 | Viking VUWC140 Wine Cooler
The light is on even with closed doors
How do you know since the door is closed? Assuming it is, it has a bad door switch. Replace it.
Viking wine refrigerator flashing red light
what is the model number is then we can get started then okay??
Sep 11, 2013 | Viking VUWC141 Wine Cooler
WAS TOLD TO TRASH VCWB300 WINE COOLER BECAUSE OF FREON LEAK VERY SUSPICIOUS
Do you know what type of freon it is? And how old of a unit is it? Why was the service technician initially called?
Mar 17, 2013 | Viking VCWB300R Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Jun 17, 2009 | Danby DWC283BLS Wine Cooler
Change light in wine cooler
Took everything out and got on my back with flashlight to find a tiny screw holding lens in place.  Found that a little night light fit and worked fine.  Wish the manual had a simple direction to fix the problem.
Jul 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Viking VCWB300R Wine Cooler Logo
16 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Jim Y
Jim Y
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
