Question about Royal VF1700MX Shredder
Ledah shredder XC 1000 overload light on - Royal VF1700MX Shredder
2 Suggested Answers
  • 1218 Answers
SOURCE: Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Posted on Oct 05, 2010
GET royal VF1000MX manual
tesfetela.blog.com/.../royal-vf1000mx-paper-shredder-owners-manual
Sep 07, 2014 | Royal VF1000MX Shredder
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Model SPL-TXC15A. Why doesn't it operate?
The shredder may have gone into thermal overload as a result of trying to shred something unsuitable, such as a credit card or as a result of prolonged use. Sometimes operation resumes after a "cooling off" period. At others, the thermal overload shutdown is permanent.
Jan 17, 2013 | Office Equipment & Supplies
Overload error message?
1. make sure your waste bin is regularly emptied.
2. This is a cross-cut shredder...make sure you regularly "oil" the unit with shredder oil.
3. If the overload light will not go off at all,... then you have either a PCB or Motor problem...would suggest you contact Royal at 1-800-524-0799 for parts assistance.
Feb 01, 2011 | Royal VF1700MX Shredder
When I try to feed a piece of paper into the shredder, the overload light comes on and the motor stops running. It will run in reverse. Oh and when the overload light comes on, the pull out basket is...
You say it runs in reverse...does it seem to run slowly??? Have you ever "oiled" the machine.???
This is a x-cut shredder and must be oiled...get some "shredder oil " and try pouring some of the oil across the cutting blades and running the machine in reverse. See if it seems to pick-up some speed after the oil in tried. Then see if it will run in the fwd direction for you.
Dec 07, 2010 | Royal VF1012mx Shredder
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Nov 24, 2009 | Royal Office Equipment & Supplies
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Royal VF1700MX  Shredder Logo
63 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
