Question about Saitek Executive PZ18AU Keyboard
Repeating key - cause unknown
After a brief power outage., my USB keyboard (Saitek Eclipse) randomly generates a ".".. Either whi.le typing. or simply sitting .on a blank document. (I'.ve left these in for example).
I have disassembled the keyboard completely (A+ cert. tech.). There is no debris under the. keys, on the. rubber-like skin underneath., nor is there any visible damage. or debris on the. circuits...I assume thats what it is...more like several layers of overlay with schematics.
Anyway..Saitek support is no help...any suggestions for salvage.? Thanks.
Re: Repeating key - cause unknown
No solution here, but I'd like to second that I have a Saitek 1st gen keyboard. One day it began exhibiting the same problems that you are having. When moved to another computer it seemed to work for a month or so but then started acting up again. For my keyboard, it repeats the letters "a" "s" "m" and others. Not sure what is causing it. No spills on the keyboard and it is fairly clean.
Posted on Feb 17, 2008
0 characters
3 Points
On Saitek eclipse II illuminated keyboard: What is function of the 1 (above the f8), the A (aboveF9) and the down arrow between F10 and F11) Also the function of the dey on bottom row between the windows...
The 1, A and down arrow represent the usual Num Lock active, Caps Lock active and Scroll lock on option available on all keyboards out there.
The 'dey' key on the bottom between the Windows Key and the Ctrl acts as a right mouse button, as in opening the menu you would open with the right mouse click.
Hope it helps.
Dec 31, 2010 | Saitek Eclipse II Illuminated Keyboard
I have an HP Pavillion ze5300 laptop, and most of the time (15 out of every 20 minutes about) the "]" key keeps repeating. Sometime I can type if I am pressing the backspace key the entire time, but that...
It sounds like you need to replace the keyboard. Replacing the keyboard is not difficult or you can take it to a repair center. Parts can be ordered online from HP or aftermarket vendors.
Dec 09, 2009 | Saitek Executive PZ18AU Keyboard
I am experiencing the same problem
Try the keyboard in another computer.
Try another keyboard in your computer.
If another keyboard works in your computer, and your keyboard fails in both computers, then it's time to replace the keyboard.
Aug 13, 2009 | Saitek PZ30AU Keyboard
Saitek Eclipse Keyboard Keys stopped working
this could very well be your OS as much as your keyboard. Try another board for a few days and see if it still happens. IF found your culprit. Replace the keyboard or look for updated drivers if they exist.
Jun 02, 2009 | Saitek Eclipse II
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Jan 16, 2009 | Saitek Eclipse II
Saitek eclipse illuminated keyboard
Are the keys working?
If the keyboard is doing absoloutly nothing, then it may have drawn too much current from the USB port and shorted it out.
Try something else in the USB port and see if that is working correctly like a flash drive/mouse etc
Apr 13, 2008 | Saitek PZ30AU Keyboard
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
Saitek Eclipse II: how to retain color choice after computer sleeps?
I think it is just the way it is. mine does that as well. b/c mine does the same thing on any computer i have it pluged into though.
Jan 16, 2008 | Saitek Eclipse II
Saitek Eclipse II Lighted Keyboard
Changing the default colour involves a little dis-mantling. remove the screws from the back of the board. Carefully remove the rubber feet inserts too as there are 4 more screws under there. Now remove the top section of the keyboard (the bit with the keys) Lay the board down flat and you will notice where the usb cable comes in a circuit board. this has a connector with 4 wires attached to it on the left hand side. the wires are coloured red, grey, blue and black. Remove the connector and swap over the Blue and Red wires. Re assemble the keyboard after reattaching the connector to the circuit board being VERY careful not to overtighten the screws. Now at boot up the keyboard will by default be red.
Sep 15, 2007 | Saitek Eclipse II
Saitek Executive PZ18AU Keyboard Logo
615 people viewed this question
Top Saitek Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Saitek Keyboard and Mice Expert? Answer questions, earn points and help others
