Question about Timex Watches
Are vivani watches waterproof - Timex Watches
Is my fossil watch waterproof?
No watch is waterproof.
It's water resistant; see back of watch for details.
5ATM = 50meters etc.
Jan 24, 2016 | Fossil Watches
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
I have a vivani conture watch cant take of the watch off to put the battery in
A process called knifing is used to remove some watch backs but it has to be done carefully to prevent damage to the case or yourself
Oct 26, 2012 | Watches
Is the Sharp watch shp5759 waterproof
No such thing as a waterproof watch in the USA. Watches are rated for resistance to different depths. If it just says water resistant it means you don't need to remove it to wash your hands. If it doesn't say anything it is water resistant.
Oct 01, 2012 | Watches
Is this watch water proof? Could I go for a swim timing myself would the watch be ok or would it destroy the watch?
mcdevito75 here, If your Timex is a quartz watch then NO, water will destroy your watch. If your Timex is a windup, it must say waterproof and even if it does, every 2 years it is adviseable to see a watch repair shop for up dateing the waterproof status of any watch. I would advise not to use your Timex in any large amount of water.
Aug 17, 2010 | Timex Expedition 40141 Wristwatch
Have problem with moist on the inglio watch
If you have a moisture problem, bring the watch to a watch repair specialist and tell them you need a new seal or for them to check the seal behind the back cover. After the seal is removed or replaced, the waterproof guarantee is then void and the maker can no longer guarantee that the watch will then be waterproof.
Oct 05, 2009 | Watches
Vivani watch has multiple dials and buttons but no response
Yeah I have the same kind of watch. The three small dials are ornamental and nothing more (this is obvious because their denominations are 60, 60, and 24, instead of something useful like 1-12 month, 1-31 for date, and 7 days of week). The extra two spring buttons are probably the same... nothing but ornamental. You could verify this by taking the back off the watch and seeing for yourself that they probably press nothing at all. Are simply there for maybe some other design where the case is uses,to illuminate the dial or other thing not on the watch. Vivani watches seem to be simple watches that are very ornamental and pretty (i.e., dress watches on the cheap) but completely lacking in features at all.).
Apr 16, 2009 | Watches
Watches Logo
19 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
