Electrolux ewf1282 keeps beeping for no reason.. Please help..
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: electrolux ewf1282 wont fill with
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Jul 10, 2011
  • 6277 Answers
SOURCE: Electrolux ewf1282 locked door, flashing
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Oct 15, 2011
kevin_getz
  • 1031 Answers
SOURCE: I have a electrolux ewf1282 washing machine with a error code EH1 can you tell me what this is
Incorrect mains frequency-The power supply frequency is not within the configured limits.
Posted on May 19, 2012
How do I turn off the beeping noise on the Electrolux 7kg Time Manager washing machine the 5kg Electrolux Sensor Dryer? The beeping noises indicating a cycle has finished are very loud. Please help!
The acoustic signals operate when:
• The programme is completed.
• The appliance has a malfunction.
To deactivate/activate the acoustic signals, press "Drying level" and "Prewash" button at the same time for 6 seconds.
If you deactivate the acoustic signals, they continue operate when the appliance has a malfunction.
Dado
Mar 06, 2016 | Electrolux Washing Machines
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
Hi I have an Electrolux EWF1282. We didn't realise the drum had come came off one of the springs and it dropped but we put the spring back on now it won't spin
check that the lever that switches the machine off for out of balance is on the correct side of the switch
it is normally the same switch that controls the lid to stop the machine when it is opened
when the drum dropped down and you lifted it back up it is possible that the lever is on the wrong side of the switch
Nov 11, 2015 | Electrolux Washing Machines
Why does my Electrolux dishwasher keep beeping 20 continuously?
call electrolux i cant find anything that is free,they all want money
May 09, 2015 | Electrolux Dishwashers
I am after a picture of the motor wiring on an ewf1282 front load Electrolux washing machine. There is a spare yellow wire which comes from the ECU, but the only place it looks like it will attach to
Good Morning Friend,
I understand that you are looking for a picture of the motor wiring for your Electrolux washer, model# EWF1282. This appears to be an Australian Electrolux dishwasher. I suggest contacting the manufacturer directly. They might be able to get you a picture of the motor wiring. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Electrolux Washing Machines
Electrolux washer playing up!
Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
Jun 28, 2013 | Washing Machines
E9F code
Communication problem. Check the wiring between the Main Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board. Here is the part you need.
Oct 13, 2012 | Electrolux Washing Machines
May 18, 2012 | Electrolux Washing Machines
Electrolux ewf1282 wont fill with water
heatman101
Jul 10, 2011 | Washing Machines
Fridgidaire dryer beeping and flashing lights
Download the troubleshooting instruction sheet here ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134509400efs.pdf
Follow the instructions and reply back what you determine and I will help further.
Jan 28, 2009 | Dryers
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
