Acer z5101 not booting up
I'm getting power to the acer z5101 but there's no beep to tell me it's booting up,other words when I switch on my pc its not booting up but has power as lights come on,,?
Giddion
SOURCE: Acer Veriton 6800 PC Desktop will only beep will not boot.
reseat ram for a fast beeping and disconnect the power supply both the big and 4 pin connectors for 2-5 min plug in and boot. Plus you do not have to have pairs of mem only if you wand double data rate
Posted on Jan 10, 2008
SOURCE: PC is hang up about 5 mins after boot up.
I just recently have reinstalled window XP Prof on Acer Aspire T180 with Window Vista originally. Every hardware works fine. I downloaded all the drivers for Window XP from Acer website. However, the PC just keeps hang up on me after 2-10 minutes after boot up. I have to Power cycles it to get it starts again. Any helps will be appreciated. Thanks
Posted on Aug 10, 2008
bob_computer
  • 3153 Answers
SOURCE: Acer T180 powered up all i get is beeping . From the hard
The beeps you refer to are known as "computer beep codes" and may also be known as "computer post codes" although they are in fact slightly different with the post code being the more technically descriptive of the two.
These are very descriptive and can tell you exactly where to home in on the problem.
In the back of your manual should be a list of these beeps and if you listen very carefully the are quite similar to morse code it is this distinction the gives you the information. If its not there then you should go here
http://www.postcodemaster.com/
You need to scroll down to the beep codes.
or try here
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml
Sometimes it is just a matter of opening the computer (good time to blast the dust bunnis with a $3 can of compressed air (outside of course) and then remove each connection (one at a time) and reconnect before doing the next one.
You should do this with all the cards, rem, and cables. (computer off AND disconnected during the above)
If any of the connections seem difficult the look for a small pusf in latch on one side of it and push it in whilst wiggling the connection gently.
When you have done connect and try your computer again.
If you were lucky it may now work again. If not you may have to seek more help at your local repair shop.
Posted on Aug 11, 2009
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
  • 5 Answers
SOURCE: Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Posted on Apr 03, 2011
I got problem with my acer aspire z5101 it's not
i dont understand u,,if your destop is not showing but got a background only then u should hit ctrl alt and enter enter.the task menu will popup and press new task and find the link c:\windows\explorer.exe or c:\windows\system\explorer.exe and run it
Mar 28, 2012 | Acer Computers & Internet
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
Acer aspire 9300. Get 3 loud beeps when trying to boot. Will not boot.
3 beeps usually indicate a memory failure. if you have more than one memory module try powering the computer with just one of the memory modules installed.
Mar 30, 2011 | Acer Computers & Internet
I have no screen on my acer aspire 9300 it powers up and then I get three beeps the first longer than the second two and then just a blank screen?? Please help
When you hear some beeps before a computer boot it means that it didn't pass the POST (Power On Self Test) phase. Taking note of the sequence of the beeps and checking the manual should tell you the reason, for example bad memory, no HD found, bad processor, etc....
Looking at your model manual here below the codes are not indicated but Acer ask to call their tech support (see page 43)
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS%209300_7000%20User%20Manual.pdf
Anyway the 1 beep long and 2 short means 1 long, 2 indicate a video error and the Bios cannot initialize the video screen to display additional information.
You may have to replace the video card.
regards
Mar 16, 2011 | Acer Computers & Internet
Acer Aspire T 180 stops with Acer Logo
What you were trying to do tried to remove the RAM and boot your pc. Buddy once you remove your RAM you are going to get long beeps as it tells there is no RAM on mother board and it won't boot. Just install back all the things and let me know how many beeps you are getting and what type short and long.
Feb 22, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
Hi i have an acer aspire E380 and it doesnt boot up when switched on,it doesnt even beep. noce rare occasions it with work fine but it may take many attempts. what could be the cause many thanks.
Your problem is either with your power supply or motherboard, but being as it boots somtimes and then dosent, and not even a beep, then the power supply would be the main cause, i sugest taking the power supply out of the computer and taking it to your local pc store, ask them if they could test it for you before you buy a new one. hope this helps.
Jan 30, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
Boot problem
You would need to note whether the 8 blinks are in a specific order; this is probably equivalent to beep codes and the spacing (grouping) of the beeps/blinks may tell you what problem you are having (other than having clumsy buddies).
Check to see if they are grouped in some recognizable manner such as 3-3-2 and then you would have to check with Acer to decode the sequence. Depending on whose BIOS is installed in your model, the 8 blinks equally spaced may be valid too and tell you the nature of the problem..
An example of the 'beep' codes can be seen here, midway down the page:
http://www.techsupportforum.com/hardware-support/laptop-support/163870-acer-aspire-5100-three-beeps-no-screen-boot.html
Oct 18, 2008 | Acer Aspire 3680 Laptop
Hi Just checking first of all you have tried another memory module. This sounds like a faulty RAM. Please try and get back to me if that doesn't fix it. Thanks, Lolita
Jun 02, 2007 | Acer Veriton 6800 PC Desktop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
