Question about Utilitech Plumbing
Utilitech pro submersible pump has good electrical connection but pump won't start
I'm getting 120v per leg below the splice on the pump side but the motor isn't working. The breaker isn't switching off, so I don't see a problem there.
  • 104 Answers
SOURCE: no water on submersible pump
I assume this is a new instalation or you just removed and reinstalled to pump. As you have power on the load side and we assume your wiring to the pump is correst, you need to open a valve on the output side of the pum and bleed the pump. They will become air bound, Leave the valve open until it flow freeley. That should do it
Good Luck
Posted on Feb 07, 2009
  • 523 Answers
SOURCE: I am replacing my well pump/motor and need the
This attachment should answer any questions you may have on the electrical connections
http://www.franklin-electric.com/business/WaterSystems/service/AIM/default.aspx
Tom
Posted on Oct 03, 2009
john224
  • 1378 Answers
SOURCE: i installed a new pump, motor and timer, but the
Be sure you are actually one the L1 and L2 posts and/or screws. On some of the motors there is a third quick connect tab that is not used when set for 230V lines but if you connect one of your incoming line leads to it the motor wont work. If that is not the case, be sure you have a resistance reading somewhere close to 1 ohm across the L1 & L2 terminals. If you get infinite, there is a problem with the motor. I assume the motor is completely silent when you turn on the switch? If not and it is humming but not starting, have the capacitor checked and if necessary, the motor start switch and winding.
Posted on Oct 30, 2009
  • 18 Answers
SOURCE: tsurumi submersible vancs series pond pump has
To get a new owner manual send them an email and they will email or send you one,
info@tsurumiamerica.com
Is the pump was working fine for a long time before that happen?
if yes
There is a motor problem,
You can check your pump power cable try to find any damage or hole in it.
If the cable fine
And if the impeller and wheel still turn before triping the breaker It would be a good thing to check the amperage with a special electronic tool to see how much amperage the pump take,
or
if you are good in manipulating tool we can send you the breakdown or i can support you to open it and to check the motor trying to find any burn part in it. That way we will know right away if its worth to fix it.
let me know
Posted on Nov 11, 2009
heatman101
  • 43501 Answers
SOURCE: some submersible pumps have a gray motor box to
The difference in the two pumps is that with a three wire pump the start and run capacitors are in the gray box. With a two wire pump the caps. are built into the motor. Because of this with a two wire pump you only need to run the 240v down the well to the pump. The yellow wire on the three wire pumps is the igh voltage wire that come from the start cap. I have used both pums but usually use the two wire because they are easier to hookup and the wire is cheaper because you only need to run three wires. (2 hots and ground) On large HP pumps you will always have three wire motors because the caps. get too big to get them in the motor. It is best to go three phase with big pump if you can.
Posted on Nov 14, 2009
Where can I buy an adaptor for a Utilitech 1/3 HP Submersible Pump #0435062, PPSU33? I called Utilitech and they were no help.
the best place to get help here is from a pump and irrigation supply shop
they will have everything needed to operate the pump
Feb 08, 2017 | HP Plumbing
Utilitech pump model KLHO75 manual
Lowe's has the manual for the Utilitech KLH075 0.75 HP submersible pump on the product site: http://www.lowes.com/pd_240035-84862-KLH075_0__?productId=3880627 . Click on the Info & Guides tab. The direct link to the guide is http://pdf.lowes.com/installationguides/717301122392_install.pdf . This is labeled an installation manual. The operating instructions start on page 6.
I hope this helps.
Mar 24, 2016 | Plumbing
Any suggestions when a newly installed utilitech pump won't turn off?
its sucking dry or your wiring is not right, or of course an airleak, or the prime is not good, did you fill the pump prime hole at the 3/4 plug on bottom.of pump, deep well pump do you mean submersible? if so and it is a deep well submersible there is a prime, its got to be an airleak in the line or the pressure tank is not pressured up to the specs, and the gauge
May 16, 2015 | Jet Plumbing
Only one yearold;turn on,or plug in kicks breaker
Roger, DO NOT USE. Return to place of purchase, or cut cord and discard.
Apr 24, 2015 | Utilitech 0.33-HP Thermoplastic...
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Why won't my Utilitech dusk to dawn light work
If you know the bulb is good, try changing the photocell. Why is it half of the problems on this site are Utilitech? I think I see a pattern.
May 28, 2014 | Utilitech 0.33-HP Thermoplastic...
Purchased new well pump have electric however the pump will not start
Does the pump hum? Sounds like start capacitor is bad in control box.
Apr 03, 2014 | Utilitech 1-HP 18-GPM 3-Wire 230-Volt...
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
Short in well
the best would be to rewire and check if its running in a bucket of water, if all is ok then seal it with a epoxy resin cast
Apr 07, 2013 | Utilitech 1/2-HP 10-GPM 2-Wire 230-Volt...
No water on submersible pump
Good Luck
Jan 23, 2009 | Submersible Systems 1/2HP 2WIRE...
Plumbing Logo
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
