No color TV on my Trutech 7'' LCD TV + DVD under the cabinet model KLV3170
I can watch dvds OK in color but not regular TV. I've tried everything with no results. Is there a secret button I cannot see? The set is in Brazil, where the voltage is the same but the TV system is not. My other American LCD works fine in color, but this one I see color only playing dvd - the black and white image is perfect, only with no color. Thanks for your help.
  • hyppolito Nov 24, 2007
    The DVD is not separate but built into the unit.
    That's why I expect some sort of configuration
    is needed in order for it to work. I'm in Brazil now and the Sharp LCD had a switch that
    made it adaptable to the local syatem.
    I'm illiterate in this so I haven't really searched in the right places for the right answer, hence my joining this program. Any chances?
  • hyppolito Dec 07, 2007
    It is a KLV3170?
    Sergeant:
    Champion:
  • 298 Answers
The colore frequency is a little bit different so
tho over the air picture is effected probably
more so in the city I think Brazil has PAL-N
which is more off than NTSC or PAL-M
Posted on Nov 24, 2007
  • 363 Answers
The TV broadcast system in Brazil is PAL-M.
If this TV was bought from the US then the TV will be expecting the NTSC system.
Your other American TV may be a multi standard TV and is able to detect and adapt to your PAL broadcast system. Not all TVs do this.
How do you connect the DVD to the Trutech TV? Is it with a Scart connector? If so then the TV will not be using any broadcast standard at all and that is why it works properly.
Unfortunately if you have searched all the menus and manual instructions without finding a TV system selection, then this TV may never be able to receive TV broadcast in colour.
  • Martin B
    Martin B Nov 25, 2007
    Yes I see now, the title for this problem is a bit vague.
    Obviously with the DVD player built in there is no need for TV system encoding, it is probably straight RGB.
    Now in order to dignose this problem with any accuracy we would need to know the model number. After a bit of work I suspect this to be PVS12701. Please can you verify?
  • Martin B
    Or maybe it's a KLV3170?
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
Oct 04, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba HDDVD Player Model HD-A3
well your TV has a 1920 x 1080 Pixels hi resolution is this what you mean?
I would hook up your HDDVD via HDMI to the TV and the regular DVD to Component1 on the TV,
hope this helps
Jan 13, 2008 | Sharp LC-45GD7U 45 in. HDTV LCD
I have a trutech tv KLV3170 but I've got a rca universal remote I need the code for it
047,029,084,092,000,055. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 19, 2013 | RCA Universal Remote Control
Tv dvd combination is not taking a dvd
It does not require a special cable for the DVD it is attached to the TV internally. If the regular signal input cable is OK then the problem is within the set itself, which I might add is quite common
Gillight
Aug 27, 2012 | Venturer Klv39103 10 Under-Cabinet Lcd TV...
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
I need to purchase anothe remote for my Trutech under cabinet DVD/tv combo. could i get the number to call Trutech or anybody that can sell me another remote please..
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Need manual for trutech product
go to the trutech website and you should be able to download a manual there.
Nov 29, 2008 | TruTech TT320
TV won't playback DVD-RW Disc recorded on another TV.
THE PLAYER IN THIS MODEL DOES NOT READ DVD+ OR DVD- OR DVD RW DISKS ITS NOT GOING TO HAPPEN! CHEAP PLAYER INSIDE WILL ONLY PLAY STORE BOUGHT DVDS
Nov 23, 2008 | TruTech PLV16320 Television
Yellow?
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores, so many different companies make their products. This website isn't the official site for ALL Trutech products, just some of them, like this 19" LCD TV/DVD combo.
Aug 12, 2007 | TruTech PVS2119 19 in. LCD Television
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
