Question about Poulan WeedEater Hedge Trimmer 25cc Engine
Morrison hedge trrimmer broken fuel line - Poulan WeedEater Hedge Trimmer 25cc Engine
Wh does my electric hedge trimmer shuts off when I angle it.
It is not getting enough fuel for some reason. Either water got it, the gas is bad, the line may have a hole in it, ect. Check fuel/fuel tank
Jul 29, 2014 | Troy-Bilt Troy Bilt Tb24htb 24" Dual...
How to change fuel line on Husqvarna Trimmer 128L
They are juat a pull in fitting. Get access to the fuel tank, the broken fuel line should just pull out the tank. The new full line goes back in through the top, just pull through into the tank until the hole in the tank sits between the 2 flanges on the fuel line.
Mar 20, 2013 | Husqvarna 128L Line Trimmer
Poulan hedge trimmer GHT 225 it is a dash 2 How to adjust needle valves after replacing fuel lines (they are on the correct sides) the switch wires aren't pinched or broken and fuel seems to flow when...
The small green rubber thing sounds like the duckbill vent for a gas cap. Since the gas cap vent sits right over the open hole of the tank, I would check the underside of the gas cap. See if the little rubber vent is there. Normally, they will use a small clear nylon connector to hold the return line inside the tank. The small green thing sure sounds like a fuel cap vent. Here is a link to the diaphragm carburetors site with a tutorial on tuning these little carburetors. I will give you one from Zama and one from Walbro....Zama first.
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Jun 08, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
The trimmer starts but will not keep running, I replaced fuel lines and filters and put a rebuild kit in the carb. Same problem, starts fine but will not keep running
Its a longshot but I had a problem with my hedge trimmer, it kept cutting out when idling.
It turned out that a clutch spring was broken so the clutch shoes had nothing to restrain them and would fly out and make contact with the clutch drum and stall the machine.
Air locks in the fuel lines will also cause this symptom. These can be caused by running the machine with low fuel level in the tank and cutting upside down or at a sharp angle.
Mar 01, 2011 | Echo Gas 20 In Bar Double Reciprocating...
The gas line has broked into, can that be replaced?
Yes, that can be replaced, but, you need to make sure you replace the broken line with a treated fuel line. That just means that it will hold up to having fuel run trough it.
Most of the big box supply stores have the hoses pre-cut, and pre-packaged in the lawn equipment department.
I hope this is helpful.
Jan 30, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
How to get new plastic fuel lines in fuel tank in my weed-eater hedge trimmer. the line is larger than the hole in the tank.
Oftentimes it helps to use scissors to trim back a portion of the new line. Start at the bottom and cut upwards at an angle. Put some lubricant (WD40, perhaps) on the line and slide the sharp point into the fuel tank. Using needle nose pliers, grab the line and pull it through. This will only work if you have the correct size line. If the new line you are using is too large, you probably can't pull it through.
Apr 20, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
How to put new fuel hose into fuel tank on jonsered hedge trimmer The hole is smaller than hose
You will need to split the fuel line for about 2 jnches and push it through the hole then reach in the tank with needle nose pliers and pull it through.Then cut off fuel line square and install filter.
Mar 14, 2009 | Garden
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
27 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
