Question about John Bunn Neb-U-Lite EV Nebulizer Compressor JB0112-061
My neb-u-lite ev doesn't steam - John Bunn Neb-U-Lite EV Nebulizer Compressor JB0112-061
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
CAN YOU PLEASE EXPLAIN TO TO ME WHAT IS EV COMPENSATION AND HOW DOES IT WORK
EV compensation is "Exposure Value compensation". The camera contains an exposure meter which determines how much light is on the scene and sets the exposure appropriately. However, this meter does not know WHAT you're taking a picture of, nor does it know what effect you're going for. The best it can do is to assume you're taking a picture of an "average" scene and want it to be of "average" brightness. It does this by assuming the scene is "middle gray," halfway between black and white. Most of the time this works fine, because most scenes are, well, average.
However, this is not always the case. Suppose you're taking a picture of a white dog playing in the snow. Almost everything in the scene is bright white, but the camera doesn't know that. It tries to make the scene middle gray, and the result is that you get a gray dog playing in gray snow.
On the other hand, suppose you're taking a picture of a black cat sleeping on the hood of a black car. Here everything is black, but the camera doesn't know it. It tries to make an average scene, resulting in a gray cat sleeping on a gray car.
EV compensation allows you to override the camera's exposure setting. In the first example, you'd want to add two or three stops (positive EV compensation) to force the camera to render the dog and snow as white instead of gray. In the second example, you'd want to subtract a stop or two (negative EV compensation) to render the cat black instead of gray.
How much EV compensation is correct? Well, that depends on the scene. With a digital camera, you can look at the picture and see whether the dog looks white or the cat looks black. Film photographers take lots of shot, using various levels of EV compensation, so that one of them would come out right.
Mar 19, 2011 | DXG Technology DXG-505V Digital Camera
I need a manual for a neb verona ss fe2623exx oven
I have a manual for this oven which I can copy and email to get the grill to work you need to in this order.
Switch oven temp to max
then set function to grill
then set grill temp to what ever.
If you dont do it in that order the grill wont come on for some raeson.
Feb 26, 2009 | Verona Ovens
Hudson nebulizer leaks
If tap water is used, you may have a buildup of lime deposits; allow it to dry and then look for any white deposits.
Using distilled water will avoid this.
Feb 13, 2009 | Hudson Rci T UPDRAFT II NEB MOUTHPIECE...
Am i hooking this nebulizer up right
First when you turn on the neb is it running and putting out air
second is the circuit or medicine cup you have new?
if not replace if yes connect tubing to spout on neb, connect other end to bottom of cup open up and put medication inside ( you can do a trial run with water just to make sure its puffing before you waste meds.
put on mputhpiece turn on should puff out like steam if not you compressor may not be putting out enough air if over 5 years old insurance should help purchace a new one with a dr rx if not call company you got it from they usually have a 5 year warranty on them.
Hope this helps
Feb 09, 2009 | DeVilbiss Pulmo Aide Compressor Nebulizer
Probasic riteneb
If it looks like fog coming from the mask it is doing it's job,If not,the filter may need changing.(A little water goes a long way in those machines)
Jan 07, 2009 | Probasics Rite-Neb Mini Compressor...
Nebulizer filters
Hello annb19702,
The nebulizer you have is made by Invacare Supply Group. You can order online at onlinemedicalsupply.com or you can call them at 1-800 860-0305. Have a nice day. and please dont forget to rate me.
Mike
Sep 19, 2008 | Probasics Rite-Neb Mini Compressor...
Help me
battles. let them hold a macho brace, makes them earn more exp. or an exp. share too.
Jan 11, 2008 | Nintendo DS Lite Console
John Bunn Neb-U-Lite EV Nebulizer Compressor JB0112-061 Logo
46 people viewed this question
Top John Bunn Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a John Bunn Health and Beauty Expert? Answer questions, earn points and help others
