Question about Home
Ott lite floor lamp won't turn on
Tried new bulb. Will not come on.
2 Suggested Answers
ddinneb
  • 200 Answers
SOURCE: removal of burnt out bulb in ott lite
Depending on lamp the bulb is approximately a 1/8 turn with a slight push toward the base to release the bulb, If you have not purchased the replacement bulb take the old one with you, some "high end" lamp stores will have replacements, if not the website will help. Good Luck!
Douglas
Posted on Jan 28, 2011
Replaced two bulbs and both have blown when switching on.
Having worked in Electronics & Electrical R&R {part time} since I was 25, I've encountered this dozens of times: If/after you have already tried the most obvious & logical solutions without success, try these: (1) Make absolutely sure (!) that the new Bulbs are the Bulbs that meet the Oven's Electrical Specs. Don't rely on a Salesperson or a Friend's assurance! You need to be 100% positive they are eclectically identical as the Original Bulbs. This might require you to gain {it's simple; anyone can learn this}
some Basic electrical knowledge, but if the Bulbs are not exactly
the same you could spend a lot of Money on repairs that were never needed! (2) Heat is the most common enemy of All electronic & electrical parts! Heat eventually degrades {and can destroy} the functionality of the Receptacle the Bulb screws into. No matter how
"new" your Oven may be, if you have tried all the obvious First solutions to no avail, try the same bulbs in a new Receptacle. I realize that in an Oven this will not be easy or simple to do, and may be very expensive to accomplish. So, try to locate another Oven the same Model & Age as yours, and use the same new bulbs in it. If they don't burn out, use the same Bulbs in your Oven. If they burn out and after you have tried all the other solutions, instal a new Receptacle. Even if that does not fix your problem, a new Receptacle is never a bad investment. (3) If nothing else works, you'll need the service from a Repairman who knows how to use a
MultiMeter to check all the Electrical Specs. of your Oven, starting with the Receptacle. Or, buy a new Oven. Nowdays, using the Service of a Repairman who knows how to use a MultiMeter is more expensive than a New device.
This isn't Theory-- I have solved many Electrical problems by changing Receptacles.
Hope this helps You or someone else!
Jan 16, 2016 | Ovens
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Pass head light will not work i tried new bulb
check for broken ground
test for power at the wire
May 06, 2010 | 1998 Chevrolet Cavalier
Right low beam headlight out. Tried replacing
id be checking the fuses as they are run on seperate ones.
Dec 08, 2009 | 2004 Ford Explorer
Tried to change bulb but now wont work
Insure the batteries are working correct and in the proper direction. Also double check the bulb to isure it was not damaged and put in correctly. If it was working before new bulb inst. try a new bulb
Jul 30, 2009 | Mag Instrument AAA Mini Maglite...
Can't remove bulb cover to install new light bulb. Tried turning counter clockwise - no luck.
Hi, If there are no metal fasteners on or around the bulb to holld it in, it will need to be twisted. Try and put a towel on the lens to help you get a better grip.
It sometimes take a great amount of force to turn the lens.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kitchen Ranges
Left brakelight and left indicator not working
check the fuses ,;also with two bulbs blown ,clean the contacts inside the bulb holder ;they are easily coroded
Nov 06, 2008 | 2004 Ford Freestar
HLM6517W 61' SAMSUNG DLP TV HAD GOTTEN 3 FLASHING LIGHTS ON FRONT SENSOR REPLACED BULB WORKED FINE THE NITE WE REPLACED IT WOULD NOT START IN AM TRIED BUT WOULD END IN 3 FLASHING LIGHTS AGAIN? IS IT NOT...
NEW BULB, NO SCHREETCHING NOISE, WANTED TO WORK BUT SOMETHING WAS NOT FIRING.... TRIED A NEW BALLAST! AND YES IT WORKS TURNS OFF AND TURNS ON!!!
Oct 12, 2008 | Televison & Video
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Home Logo
452 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
