I need a vizio sb4020e-a0 sound bar code for dishnetwork remote
Gigatech
  • 259 Answers
SOURCE: remote code
Magnavox 0054, 0706, 0030, 1454, 1254
How do I program my remote control?
For remotes that have blue arrow and Select buttons and 4 separate mode buttons (SAT TV VCR AUX):
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again.
  • Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (click here to view remote codes). The light will blink off after each digit is entered and then return to a steady light.
  • Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment.
For remotes that have one Mode button at the top:
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over.
  • With the desired equipment on, press and release the Mode button until the light flashes behind the correct mode.
  • Using the tip of a pen or the eraser on a pencil, press the address button.
  • Enter the code (see links to find your code below) on the remote's numbered keypad for the equipment.
  • Press the Address button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment. Some codes may provide partial functions or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Click here for codes for remotes with blue buttons.
Click here for codes for remotes with gray buttons.
Click here for codes for platinum (DVR) remotes.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
markevans
  • 148 Answers
SOURCE: Dish Network Remote
not every remote is capable of controlling every unit via remote codes. however, there is a set up in the manual that takes time to use. basically you will use the output from one remote to establish the same output for the new remote. its a step by step process. try a universal remote such as theater master which allows you to use a computer to control functions by assigning them to certain keys. this will be far easier. the mx700 is a capable unit for complex functions on multiple equipment and has a screen to guide you during actual use as to what each key is going to do. you will set up the specifications yourself, such as channel up or channel down, or menu or guide. you get to use already established key locations or choose from 10 along side the screen to state whatever you want, and then after its set up, those buttons do the work you programmed them to do.
good luck
mark
Posted on Dec 24, 2007
  • 133 Answers
SOURCE: Remote code
Have you tried the website of DISHNETWORK.COM yet?
Posted on Jul 23, 2008
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Posted on Dec 29, 2008
SOURCE: i need codes to program my vizio sound bar to my
need 3-digit code to program Vixo sound bar to Dish Network 5.4 IR remote
Posted on Feb 21, 2010
Vizio TV has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
Why did remote control quit working?
Replacement batteries could be defective or installed incorrectly
Oct 18, 2015 | Vizio xrt112 smart tv Remote control for...
Volume does not stay level it increases by it stself
This is not a fault with its remote control. The main board to your TV should be checked. Contact any service technician. If you wish to get more details, check the site linked here.
Oct 19, 2014 | Vizio xrt112 smart tv Remote control for...
Bought a vizio tv works good it but the volume control is real hard to get it to pick up every thing else works ok. It has the right code in.
Hey sherryg98, it sounds like you have a right code, but may not be a code to give full functionality as there are many codes for a Vizio TV.
You can check out this link for more info on codes: http://www.dishnetwork.com/SupportSection/remote-setup
Some codes you can try are 627, 766, 505, 006, 232, 458, 500, 670, 678. Depending on the model of your remote there may be different codes available. I've given the steps to address a remote below just in case.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If you need any further assistance let me know here or email me at thomas.faust@dishnetwork.com
Jun 15, 2011 | DISH Network IR Remote Control
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Need dish code for remote for vizio soundbar
Hey there, this is Cheri Torres with DISH Network customerservice. I wanted to see if I could help you with the question you posted aboutthe Vizio sound bar. I was unfortunately not able to find any codes for theVizio sound bar. Another option you can try is running a channel scan to findyour code that will work best to control your sound bar. I hope that theseinstructions are useful to you. If you have any further questions or concernsplease feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Dec 27, 2010 | DISH Network IR Remote Control
I am looking for the code for my Visio Sound Bar to program into my Dish Network remote to the AUX button. Has anyone talked with Visio Support to get this code? Thanks.
ronwright22
I have provided a link for you to Vizio's Website. The information below is for a VSB210WS sound bar. I would go to this link and research your model number and look for the code. You may try the code on this screen to see if it will work. I have also provided a link with instructions on programming your DISH remote to other components.
Vizio Website:
http://www.vizio.com/vsb210ws.html
This is the VSB210WS sound bar.
Programming a Universal Remote to operate the HD Sound Bar System If you own a VIZIO TV with a Universal Remote that uses a 5-digit programming code, you may program a device button with code 31517. This will map the Universal Remote button to operate the HD Sound Bar System as follows: Pictured at right is the VIZIO VUR8P Universal Learning remote.
Ray Calo
DISH Network
Nov 09, 2010 | DISH Network IR Remote Control
I need remote codes for vizio lcd tv
Hi there, this is Kimberly Escobar with DISH Network. Ran across your post and wanted to provide you with the information you need. some of the codes for a Vizio T.V are 505,671,627, and 766 you can find more information on http://www.dishnetwork.com/SupportSection/remote-setup this link can be very helpful and help you find codes you need for any brand of T.V.
Mar 13, 2010 | DISH Network IR Remote Control
I need the tv code for a 20" vizio tv using a dish network remote from a dvr 522 receiver
Hi here are the codes for Vizio as supplied by dishnetwork
505, 627, 775, 758, 756, 885, 864
Feb 01, 2010 | Zenith ZEN700 Remote Control
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
