Question about Zanussi TC7102W Electric Dryer
Zanussi tumble dryer zdcb47209w not collecting water in the tank
hards327
  • 30 Answers
SOURCE: Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Posted on Mar 17, 2008
clair80
SOURCE: Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Posted on May 29, 2008
  • 17 Answers
SOURCE: zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Posted on Dec 18, 2008
  • 86 Answers
SOURCE: zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Posted on Feb 09, 2009
SOURCE: Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Posted on Mar 01, 2009
Zanussi tumble dryer zdc37202w where does the hose fit as i want the water to go into siphon and not the condensate tank.
Unfortunately, nowhere in the user manual does not described how the connecting hose to drain water into the siphon.
Dado
Feb 18, 2015 | Zanussi Dryers
My new tumble dyers stops after 10 minutes telling me the water tank is full, when its empty
Since it is new, I would call the mfr and have them look at it. It is under warranty isn't it?
Jan 11, 2015 | Zanussi Dryers
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
Why does my tumble drier not get warm?
Jul 20, 2010 | Zanussi ZWF1420W Front Load Washer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi tumble dryer does not get very hot
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Tumble dryer
This is the problem of your dryer's circut board. call the person from whom you have buy this and if dryer has gaurenttie period then replace if you want to get relief in future. ANKAJ
Nov 29, 2007 | Zanussi TC7102W Electric Dryer
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Zanussi TC7102W Electric Dryer Logo
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
