Question about Anker AnkeAA Ultathin Backlit Wied Keyboard for PC / Windows / Linuxs, with Lightness Adjustment Knob and Palm Rest
Resetting anker keyboards
Can't. Remember the keyboard password and don't know how to reset it
Reset password
In order to reset the password for the NComputing Administrative Console, you will need to re-install the software and reset the password through the installer. To do this, complete the following:
Launch your NComputing software installer:
  1. The installer will request a password, type anything.
  2. The installer will inform you that the password is wrong, select OK.
  3. You will then be asked if you forgot your password, select Yes.
  4. You will be prompted to restart your installer, select OK.
  5. Your password is now reset; you may Cancel the installation and access your administrative console.
Oct 21, 2014 | NComputing L230 Computer Access Terminal...
My Anker keyboard won't stay connected to my ipad, and it has stopped working after connecting tomy
Hey...umm sorry about your keyboard not working..What i cant sae is maybe u have a stickey key.
To fix this!
Replace the key on the keyboard.
Wipe off the key if you have maybe spilled somthing on it.
Jul 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How to reset bios password
You'll need to find out which screws hold the keyboard in. Usually three or four and are on the bottom of the laptop. After unscrewing them you'll have to pry off the plastic part (carefully) that is just under where your laptops screen is. Then you will see two, three, or four screws that hold the keyboard in. Unscrew those, then gently lift up the keyboard and you should see a small round button battery somewhere on the exposed part. That is the CMOS/BIOS battery. (Note you might have to take more screws out on the back if the battery is hidden under a part, but usually it is visible and you can get to it) remove that battery for 1/2 hour or longer, and put it back. This usally will reset the bios and its password. Also note tho, that some newer boards that won't work on, and you'll need to buy software especially for reseting the password in the BIOS. Youtube has some 'videos' that advertise those softwares. Try the battery thing first tho. If uncomfortable doing that first part to get to the battery yourself, you will want someone who knows how to take apart a laptop to do it for you.
May 29, 2013 | HEWLETT-PACKARD 630 Notebook
Anker user manual
I lost the instructions for making my iPad 2 compatible with new keyboard kc1280. I have Bluetooth on but keeps on only discovering and not connecting.
Nov 27, 2012 | Anker Mini 2.4ghz Usb Wireless Handheld...
Bios lockout
If their is no password on your BIOS boot into BIOS and go to "Reset to Factory Defaults". If their is a PW you don't know you will have to remove the screws and clips that hold the keyboard on. Pull the keyboard up and underneath you will see the CMOS battery which looks like a watch battery. Pull it out and leave it out for 30 minutes or longer to allow the capacitors to drain. replace the battery and the keyboard and you should be back to factory defaults for the BIOS.
Mar 08, 2012 | Acer Aspire Notebook PC
It dont accept my password
Firstly, try the obvious. You don't have your caps lock on, or if you are using a smaller keyboard laptop, you don't have the number lock on. If not, then it's possible your account has had its password changed.
You can go to http://www.facebook.com/reset.php to reset your password.
Jul 23, 2011 | Facebook Social Network
My son can't remember the pin numbers for his Dsi. How can we reset them?
Hello there,
According to Nintendo's FAQ for the DSi:
  • If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
  • If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance.
  • Hope this helped!
    May 11, 2011 | Video Game Consoles & Games
    I forgot my password for my imac, and i dont have the disk?
    Reset 10.5 Leopard & 10.6 Snow Leopard password
    1. Power on or restart your Mac.
    2. At the chime (or grey screen if your chime is turned off), hold down Command+S on your keyboard to enter single-user mode.
    3. Type mount -uw / and press Enter.
    4. Type launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist and press Enter.
    5. Type ls /Users and press Enter. This lists all of the usernames on the computer - helpful if you don't know or remember what these are.
    6. Type dscl . -passwd /Users/username password and replace "username" with one of the users displayed in the previous step. Replace "password" with a new password of your choice. Press Enter.
    7. Type reboot and press Enter.
    Reset 10.4 Tiger password
    3. Type sh /etc/rc and press Enter/Return.
    4. Type passwd username and replace "username" with the short name of the user account for which you'd like to reset the password.
    5. Type your desired password and press Enter. It won't show itself on the screen, so be careful what you type. You will most likely have to enter it again to confirm.
    6. Type reboot and press Enter.
    May 02, 2011 | Apple iMac 17" MA199LLA Desktop
    Can't remember password for administrator on a mac os x leapord
    Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
    Reset MAC original administrator account password
    May 23, 2010 | Apple Mac OS X v10.5.6
    Compaq armada 4131T
    hi,i presume that u cannot punch in the password as the keyboard is not working, except the Enter key, u can do two things, reset the bios, or repair the keyboard, by removing it and cleaning the contacts, to reset the BIOS, locate the small lethium battery, remove it and keep it outside for some time, then put it back,that will reset the BIOS.. try either of it.. let me know...
    Dec 04, 2007 | Compaq Armada 4131T Notebook
    Anker AnkeAA Ultathin Backlit Wied Keyboard for PC / Windows / Linuxs, with Lightness Adjustment Knob and Palm Rest Logo
    107 people viewed this question
    Top Anker Computers & Internet Experts
    David Payne
    David Payne
    Are you an Anker Computer and Internet Expert? Answer questions, earn points and help others
