Question about Man Kung Archery
Adjusting the draw weight - Man Kung Archery
What is good crossbow draw weight for target shooting?
12 Crossbow Do and 3 Don ts
75 lbs to 125 lbs
Draw weights for hunting are considerably higher. Assistive devices are sometimes used.
Nov 24, 2016 | Archery
Bear Compound bow. 60 draw. How much does each turn of the screw decrease the draw weight?
Have you tried this site:
http://shootingtime.com/bow-tech-basics/adjust-draw-weight/
Dec 27, 2014 | Bear Archery Encounter Compound Bow...
Draw weigth
there are allenhead bolts on each limb that connect them to the handle frame. tighten these bolts evenly (one turn on one side should be matched with one turn on the other) this will increase the draw weight you are pulling
Feb 16, 2013 | Martinn Threshold Bow Set 40-50Lb Right...
How do I adjust the draw weight on a barnett vortex lite junior bow
There are two bolts that hold the limbs onto the riser. Tighten them all the way tight or clockwise. This will ensure they are the same. Now you have to turn both bolts equal turns up to no more than 3 turns out. The looser the less weight. Never loosen more than 3 turns.
Dec 26, 2012 | Barnett Outdoors Barnett Vortex Lite Youth...
What is draw weight?
Generally, the draw weight is the amount of force to pull the bowstring to a certain draw length. The industry standard is measured in pounds at 28 inch draw length.
Aug 26, 2012 | Betsey Johnson Archery
What's the best bow for beginners?
You can findlots quality bows in different prices, but the best bow I advise you to get,the bow I actually purchased myself, is the Parker Sidekick. This bow isdesigned for beginner archers as it comes in 18- to 28-inches of draw lengthadjustable at 0.5 inch increments. Draw weights are available from 20- to40-pounds and 40- to 60-pounds with a comfortable 80 percent let-off.
Jul 30, 2012 | Archery
How should I choose my Bow Draw Weight?
Make archery fun. Choose a bow draw weight that is comfortable, less than what you are capable of pulling. Many new archers become discouraged and quickly lose interest in the sport when the bow is so heavy that it is not fun to shoot, or when the bow is so heavy that accuracy is lost. Most states have a legal weight of 40-50 lbs
Jul 09, 2012 | Archery
I have a 2003 flstci and I'm trying to adjust the rear shocks. Do I take the weight off the back tire or leave the weight on the back tire to adjust them.
The bike should have both wheels on the ground when you adjust the shocks. If you're adding weight to the bike, you can still adjust the shocks with the additional weight onboard but the adjuster will turn easier if the extra weight is not there.
Jun 26, 2011 | 2003 Harley Davidson FLSTC Heritage...
I bought an r9 supertri driver and need the manual for it. any ideas?
Movable Weight Technology TM, is discretionary clubhead weight that can be easily redistributed by the player to change the characteristics of the club. By moving differently weighted cartridges, using a proprietary TaylorMade wrench, into strategically positioned ports, CG location can be optimized per golfer. Positioning more weight in the heel and less in the toe, speeds club head rotation during the forwardswing, which promotes a draw and/or reduces a slice.
Here is a link that will definately help you with the adjustment aspects of your club:
http://www.taylormadegolf.com/mainlevel/golfshop/drivers/R9-SUPERTRI.html#30
Aug 12, 2010 | Taylormade r7 Draw Fairway Woods
Don't know where the weights go for a draw
With R9, they tried to maximize the fitting possibilities for each golfer. They engineered two independent and complementary adjustability systems into the head to cover a large range of ball-launch conditions. They use movable weight technology in combination with a variety of head angles and seamlessly integrate them into a beautiful shape"
The 430cc head features "flight control technology" (FCT). Simply, an adjustable head-and-shaft system (tighten the recessed titanium screw to an aluminum "sleeve" on the end of the shaft) gives you the ability to lock the head in eight different settings. The shaft (and "sleeve") go into the hosel off-axis by 1°, which allows you to tweak face angle (2° closed to 2°open), lie angle (1° upright to 1° flat) or loft (1°stronger or weaker than stated loft). Company brass says FCT produces up to 40 yards of directional flight variance. That's particularly good news for slicers or hookers. FCT combines with the firm's "movable weight" technology (three removable plugs that weigh 16 grams, 1 gram, and 1 gram) to generate as much as 75 yards of left-to-right shot bias, 3° difference in launch angle and 1,500 rpm of backspin. Fit yourself by positioning the face angle (FCT) and then move weights to dial in trajectory.
Oct 17, 2009 | Taylor Instruments Taylor Made R7 Quad 9.5...
Archery Logo
48 people viewed this question
Top Man Kung Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you a Man Kung Archery Expert? Answer questions, earn points and help others
