Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
How to remove the plate that covers the shark professional brush
How do I remove the plate that covers the brush
Shark rocket professional has no suction at base but hose does have suction, no clogs
I have a shark vacuum at home but I haven't had a problem with it. No
Feb 06, 2016 | Shark Vacuums
How do I change the belt on my Shark Liftaway
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Feb 22, 2015 | Shark Navigator Bagless Upright Vacuum
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
How do I replace the belt on a shark vacuum
Unplug from the wall socket, turn it over, remove bottom plate, remove roller brush, give it a good clean out, get new belt and reassemble.
Oct 17, 2014 | Vacuums
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Stripped screw on shark navigator plate
drill the head down to the shaft of the screw then remove plate, remove remainder of screw if possible, fit new screw.
Dec 30, 2013 | Vacuums
Shark v1510 How do I replace the belt?
remove the outside sliding cover... remove 2 screw in from of housing, and also the screw holding the wheel on the brush head cap side of the housing. Once screws are rmoved, you can remove brush head cap and belt cover. Pull down on belt cover to remove. It is held by screw crossing the top of the cover from the side. Belts are hard to find, but can be ordered from shark web site (2) for 7.95 and shipping.
I had the same problem. Some one should stock these belts in the states, because Shark outsources thier call center to India, which sucks. It took 20 minutes on the phone to communicate through the noise and language barrier just to order a belt!
Oct 23, 2009 | Vacuums
Shark V15Z how to change the belt
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and you're ready to go. Now if Shark will only help customer locate a replacement belt you may find this info useful...
Oct 02, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
Feb 15, 2008 | Vacuums
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
16 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
