Question about GE JVM1650 1000 Watts Microwave Oven
Everything seems to work but not heat
Ge microwave oven jvm1650. every thing runs (fans blowers lights ) but will not heat. tested door switchs ok except monitor switch when connected has o ohms when door open and o.3 when door closed. I couldn.t get connector off to check the switch but it is changing states when actuated. Do I need to check the diode next?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
The switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
Posted on May 19, 2009
  • pwrsce May 19, 2009
    the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
We have GE JVM1650 spacemaker microwave. At first it would run for 3-5 seconds and turn off. More recently it stopped heating in the middle of the alotted time. Everything works fine, no keypad...
It's a bad magnetron.
See
this FixYa solution even if your full model number is different.
Oct 02, 2010 | GE JVM1650 1000 Watts Microwave Oven
Microwave oven wil not shut off you can hear the
2 things come to mind, 1)check the door limit switches. also make sure the switches are switching at the same time. Or very possible to board is faulty. All the signals and commands come from the board. Electronic control goes faulty and things wont switcjh off.
Aug 09, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE MICROWAVE JVM1860 STOPPED HEATING
-door inter-lock switch(s) / monitor switch
-thermal cutout
-door, triac or circuit board fault
all of these could be culprit
all of these can be tested let me know if you need further instructions.
Oct 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm1650
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.
Nov 16, 2008 | GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650wb005
Mar 31, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
214 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
