Real desktop Reality engine has encountered a problem and needs to close. Reality Engine will now be closed
Drummernick
  • 440 Answers
SOURCE: win explorer encounter a problem
shut down hold oppower button in ok then boot up hold f8 to go in safe mode remove 7 ok thers sp2 for 7 out u should update with if u wann keep it ok if not use 6 and run cccleaner.com tool ok it will help
Posted on Feb 08, 2008
Nandakishore
  • 304 Answers
SOURCE: WMI Has encountered a problem and needs to close
Symptom
When you attempt to start the Windows Management Instrumentation (WMI) service, you may receive the following error message, and the service does not start:
Could not start the windows management instrumentation service on local computer.
Error 1068: The dependency service or group failed to start
Resolution
First, verify the number of dependencies attached to the WMI service. This can be viewed by running the following command from Start, Run:
CMD /K SC QC WINMGMT
The output should exactly as given below.
[SC] GetServiceConfig SUCCESS
SERVICE_NAME: winmgmt
TYPE : 20 WIN32_SHARE_PROCESS
START_TYPE : 2 AUTO_START
ERROR_CONTROL : 0 IGNORE
BINARY_PATH_NAME : C:\WINDOWS\system32\svchost.exe -k netsvcs
LOAD_ORDER_GROUP :
TAG : 0
DISPLAY_NAME : Windows Management Instrumentation
DEPENDENCIES : RPCSS
SERVICE_START_NAME : LocalSystem
*See attachment*
The only dependency is the RPCSS service, and it does run by default whenever you start Windows. If you have any other dependencies listed, then it may be the causing the problem. To remove the additional Dependencies, follow this:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Before you modify the registry, backup the registry key by exporting the corresponding branch. Also, see here to learn how to perform a complete registry backup.
Click Start, Run and type Regedit.exe
Navigate to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\winmgmt
Double-click DependOnService, and set it's Value data to RPCSS
Close Regedit and restart Windows
If this fails, you will need to do a repair installation..
Hope this will be helpfull
Thanks & Regards
NANDU
Posted on Mar 06, 2009
  • 597 Answers
SOURCE: closing of command promt
I would be worried about that started the cmd command. That is the command to open the old style DOS window. Usually some updates or installation programs might use the cmd window but might also be used by virus and malware installation. Does this happen every time you start the computer or just once? If it is an every time thing you need to check your start up directory and run "msconfig" to locate the program that is causing this. It would be wise to get a professional to help you. But first thing to do is reboot and run a virus scan.
Posted on Jun 01, 2009
  • 87 Answers
SOURCE: csrss.exe encountered a problem and needed to close. This error i am facing when i logged as admin to Win xp sp2 O.S
I can't be sure but it sounds like a virus.. csrss.exe often masks a serious virus. It is in fact normally a legit Microsoft program .. part of the OS. but a virus will mask itself as that file.. causing memory leaks.. if your standard virus checker won't find it.. download "unhackme" (google it).. it is a 'rootkit' killer..
Unhackme.. get's the virus (ALL virus's) out BEFORE Windows loads.. but be carefull .. it needs to be trained as it can't tell between a legit file and a dud.. just follow the simple instructions and if in doubt "get it out'!
Gaurenteed fix though and your machine will run faster too!
Posted on Jun 03, 2009
kaywon17930
  • 203 Answers
SOURCE: Every time I open any
Your problem is with your operating system. It might be corrupted. It is better for you to reformat it or reinstall your Operating System.
Posted on Jun 13, 2011
Outlook has encountered a problem
Below a link with information that may help you resolve this issue:
https://outlook.recoverytoolbox.com/
May 24, 2017 | Computers & Internet
Canister purge vavle. where is it located
I guess it could be almost anywhere. It doesn't have to be near the engine but all the ones I have encountered so far are located at the front - close to the engine bay if not actually in there.
One vehicle I recently encountered had the canister and gubbins located under the front wing and the wing liner had to be removed for access.
If in doubt I suggest you follow the pipework from the canister or back from the engine.
Dec 03, 2015 | Cars & Trucks
Intermittent opening and closing of Exhaust Valve
have the exhaust brake tappets adjusted
you haven't mentioned engine size or type so I am talking about jacob brake or dynatard brake
it is possible that when the engine oil viscosity is heavy that the clearance is nit enough
take it in to a service center for as better diagnosis
Sep 04, 2015 | Cars & Trucks
Where is the diverter/controller to send hot coolant to the heater core on a 2002 grand prix? both heater hoses are cold
Then your thermostat is closed,or your hoses are clogged, or you have an air lock in the engine. In reality, both hoses should be hot, once the engine is up to temperature. Did you recently change coolant ? If so , you may not have bled the air out properly.
Dec 03, 2014 | 2002 Pontiac Grand Prix
Install fix
try takeing it off and reinstalling it if not try reseting your computer to a good restore point then reinstall it
Apr 30, 2013 | Intuit TurboTax Computers & Internet
Oil Pressure Guage
Oil pressure is read by the sending unit, not created by it. If you replaced the sender and do not see a minimum of 20psi there is something wrong inside the engine.Some people will tell you that 5psi is "safe". In reality, in an otherwise perfect engine it may be but in real world application, the 20psi number is the lowest I'd ever accept in any engine.(at idle) Running pressure is influenced by temperature and oil grade, but this should not vary dramatically.
It is best to attach a mechanical oil pressure gauge to the engine and in that way, you can read the exact pressure. If the mechanical gauge reads the same or very close to what you see on the dash, then the reading is correct and if low you will need further diagnosis to determine why.
Oct 20, 2009 | 2001 Pontiac Bonneville
The NTVDM CPU has encountered an illegal instruction
it is a virus on your computer by the sound of it, to do a fresh install, when you initally turn the computer on, put the disc in and hit either F8 or F2, maybe F10, dependant on what it says on the inital start up screen, change the boot option to disk then you can reinstall
Jan 24, 2009 | Compaq Presario S4020WM PC Desktop
I need to know where i put the power steering fluid at
its on the passenger side real close to the fire wall on the back of the engine
Jan 16, 2009 | 1998 Oldsmobile Intrigue
My horse and me game for windows
I suspect that the reality engine will not initiate because you lack sufficient graphics horsepower (pun intended). I seem to recall that a minimum of 256mb of graphics memory is required. Have a look at the system requirements and make sure that your machine is in compliance and all should run as advertised.
Sep 06, 2008 | Atari MY HORSE & ME for Nintendo Wii
Computers & Internet Logo
David Payne
David Payne
