Question about Car Audio & Video
Hifonics BRE1100.1D Brutus ELITE 1100W Mono Class D Amplifier
2 Suggested Answers
iwear2headph
  • 9 Answers
SOURCE: I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Posted on Mar 24, 2013
"Hi I'm planning to install aftermarket stereo system on 2004 Nissan Maxima 3.5 SL ..Kenwood KDCX997 eXcelon ..Hifonics ZRX600.4 Car Amplifier for kicker 6.5 ..Hifonics BRX160.2 Brutus  for 2 8" inch...
If you have enough room on the outside edge of your battery's post to fit the ring terminal from your new fuse holder, and an additional 7mm nut, then just do that. If there's no way for it to fit, you can purchase an aftermarket battery terminal that has a separate post for mounting aftermarket accessories to. That would be the second option since it would require more money and effort. Below is a link for a few different battery terminals that should be able to use for your car. I haven't looked under the hood of 2004 Maxima since probably 2003 or 2004, but I hope this helps.
2004 nissan maxima battery terminals Google Search
Jun 24, 2017 | Car Audio & Video
Brutus elite hifonics BRE1600.1D. Not as powerfull now.
Make sure of voltage going in to Brutus.
Mar 23, 2014 | Car Audio & Video
Mar 24, 2013 | Car Audio & Video
How do i wire my kicker dcvr122 up to a 4 ohm amp
I am going to assume the 2 speakers in the sub are each 4 ohm loads, and are wired together in parallel, creating a 2 ohm load. And your amp pushes 800W at a 2 ohm load. And actually goes down to 1 ohm/1100W. Anyway...
Seems you want to lessen the wattage output of the amp by making a 4 ohm load. To do that, you need to wire the both 2 ohm speakers in SERIES.
In general wiring principles, to wire in SERIES, take the POS terminal from the amp and wire to the POS terminal of first speaker. Take the NEG terminal from the amp and wire to the 2nd speakers' NEG terminal. Then place a "jumper" piece of speaker wire to connect 1st speakers' NEG terminal to 2nd speakers' POS terminal. Now you have a 4 ohm load, and will be pushing 450W from your amp.
This way the load will now be 4 ohms.
Jan 08, 2013 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
How much should I pay for a used one?
For a class D amp from Sony at 1100W peak, I wouldn't pay more than $75 for a used one.
Feb 23, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
