Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesave XL1800 won't restart after power outage
Power went off for about 10 minutes. When it came back on micro came on and said set clock. But keypad unresponsive. I unplugged for an hour. Plugged back in, same thing. Power is on but keypad unresponsive.
  • 1 more comment
  • michael_work May 20, 2009
    I will have to get the model number later...but:
    the display lights up with jibberish at first...then moves to "set clock" but keypad unresponsive.
    Inside light comes on, yes.
    No Humming, no noise at all that I can hear.
    After about a minute of "set clock" then F3 comes on and makes a beeping sound.
  • michael_work May 26, 2009
    Sorry for delay...model number
    JVM1860WF001
  • William Miller
    William Miller May 11, 2010
    Is the display lit?
    Does the inside light come on when you open the door?
    Is there an unusual buzzing or humming sound coming from behind the keypad when the door is either open or closed?
    Does the code F3 ever appear on the display?
    What is the model number?
    (It will be something like JVM1860WB001, etc.)
  • GE Master
  • 9,085 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The keypad is part number WB27X10649.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs of $69.66 for a total of $109.61.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2009
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave unexpectedly turns off at random times during cooking. The clock face and everything dies. It is then a random amount of time (5-30) minutes before it comses back. It is not the circuit...
You could try a new plug just in case, next the fuse inside or thermal cut out could be @ fault, could be the cable transformer end as it enters the micro.....
Apr 19, 2010 | GE XL1800 1100 Watts Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Microwave Oven model JE2160. The clock and time are 10 seconds fast per minute.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise, the manual may address some settings. You can download GE owner's manuals here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Demo mode
I had the same problem trying to get rid of demo mode. Press the "clock" button 3 times in a row and problem fixed!
Jun 19, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
270 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
