Question about Casablanca Fan Dryers
Operation erratic with remote 12444R
Erratic operation with fan and lights with remote
The remote does not always control the light or fan. The light on the remote does not always come on with button depression?
The remote may need corrective therapy to restore operation. If the light does not turn on when a button is pressed, suspect batteries need to be replaced but the problem could be a stuck button. Remove the batteries and press all buttons to "unstick" them, then install new batteries and test operation.
Erratic light/fan selection can be due to power interruptions. If you disconnect power at the source and wait a few minutes before reconnecting, light/fan control may be restored.
May 01, 2016 | Dryers
Honeywell Marston Ceiling Fan. Why has remote stopped turning the light off?
Dwayne, Try a new battery in remote, if that does not fix, replace your remote, replacements can be found at the larger hardware stores, eg. home depot, lowes,etc.
Apr 03, 2016 | Dryers
Remote locking system is erratic
You may have a dodgy door light switch or the doors are not closing completely. Does the courtesy (interior) light work? Does it extinguish when operating the remote?
Mar 04, 2014 | 2003 Toyota Camry
How to sync the remote with the fan?The remote was operating the fan, but someone must have pulled the chain on the fan.
I have a ceiling fan that fails to operate under remote control whenever a power outage occurs. The solution is to pull the chain to guess which is an ON position, then operate the remote to select fan speed or off. Same routine for the light, if there is one.
Sep 04, 2012 | Hunter Fan Company 20184 H 52" Antique...
I have a hunter fan which operates using remote contraol part #85095-01. Recently, the remote has stopped operating the fan's light. The fan operates by remote, but I cannot turn the light off.
you need to replace the receiver. I ran across this problem at a customer's house and replaced it. It's located at the top in the canopy where the wires connect at.
Aug 31, 2011 | Hunter Ceiling Fan Remote Transmitter...
Fan running & stops then goes the opposite direction
Your Hampton Bay combo probably was installed incorrectly. A frequent cause of erratic operation is a conflict between the remote control and the wall switch.
Sep 09, 2017 | Hampton Bay 52 In. 5-Blade Fan, Aged...
Fan remote operates fan, won't operate light
If you press and hold the light button, it will step up in brightness to max then back down to dark. Then when you press the button briefly it will turn off and then press button briefly again it will turn on at the intensity you had it at last. So if you are one tick from off you may not notice it is "on" because it is dark. A second possibility is that you replaced the bulbs with a compact flourescent and they are not always happy with adjustable brightness, often they will be on or off, no middle ground. I recommend sticking with old school bulbs in the fan.
Sep 21, 2008 | Universal Remote Control Hampton Bay...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Remote control possibley defective
Does your remote have a variable control for the bright and dim for the light??sounds like yu have it in the dim mode..
Mar 26, 2007 | Westwind Classic Hugger Polished Brass 52"...
Dryers Logo
32 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
