Question about Air Hogs Havoc Heli Helicopters
Megabomb helicopter When power is applied rotors spin, does not lift off floor, just falls on to one side. No matter what type of floor, does the same thing. Bottom line will not lift off and fly.
SOURCE: my helicopter won't fly, it just spins around.
The top rotar blades are not turning but are slipping every now and then.
Posted on Jan 02, 2009
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
SOURCE: How do I get my
Turn the trimming the opposit way that the your heli is spinning until it stops
Posted on Nov 25, 2010
  • 1082 Answers
SOURCE: my airhogs heli does not fly but just falls to one
Right here is the support site. http://www.airhogs.com/#/need_help
This is the place to get help for Air Hogs.
They also have a "community" link which may do you some good too.
Posted on Feb 02, 2011
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
How o fix problem it just keep spinning on the floor
adjust the trim on the controller please watch some beginners videos. In this instance the problem is yaw which is left and right rotation on a helicopter it is affected by the speed of rotation of the tail rotor relative to the speed of main rotor and its gyroscopic effect. the floor cause weird flight effects on helicopters to get the trim precisely set it must be at least 4ft from the ground. but initially just get it to where it is controllable.
Feb 28, 2016 | Protocol Predator SB 3.5-Channel...
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
My helicopter won't take off, it just spins in circles clockwise until it falls over. It's a 4 channel RC helicopter with gyroscope.
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Jun 06, 2011 | RC Remote Control Helicopter Ready To Fly
Hi I have a gyro helicopter which spins in circles after taking a hit... Its a Police Gyro Helicopter from thumbsupuk Do you have any solutions for this? Thanks
Make sure that the balancer wheel/rotor at the rear is not damaged while it had the fall/hit.
If so make sure that the tails is rectified. Once the rear is damaged the helicopter stabilizes on the movement of the rear rotor as the top main rotors need a counter balance.
So it is possible that this mechanism is damaged and must be recitfied.
Dec 30, 2010 | Toys
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
My rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
May 11, 2010 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Air Hogs Havoc Heli Helicopters Logo
71 people viewed this question
Top Air Hogs Toys Experts
freddyfox
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
