Question about Stihl Garden
Diagram Teikei Carby FS65 lawn trimmer
Carburetter
  • Stihl Master
  • 1,807 Answers
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: need diagram for fuel hoses for a garden hawk
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Feb 27, 2011
  • 316 Answers
SOURCE: Lawn trimmer Petrol powered
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, 33
Posted on Feb 19, 2012
Hi my 25cc weed trimmer is not starting unless i take off the gas hose from the carbreraator an then it start an the plug keep flodding when the gas line is on ..what can be the problem ?
have the carby removed and properly cleaned out
if there is a needle in the carby ,remove it and blow out with compressed air
fit new carby kit
Nov 30, 2015 | Garden
Having trouble keeping the engine running. It will only run with the choke on, even when engine is hot. Air leak problem?
running needing the choke on indicates a blocked main jet in the carby or insufficient fuel to the carby
I suggest that you overhaul the carby , using compressed air and new parts on reassembly
Apr 18, 2015 | Husqvarna 122C 21.7cc 2-Cycle Curved Shaft...
I have an Fs65 Sthil brushcutter and the coil has gone on it. Will the coil of any aother model fit and do the job
Provided this isn't the FS 65-4 Cycle version.
PN 4114 400 1305
Coils from HS60 HS61, BG60, BG61, FS61, FS65 will interchange
This does have a replaceable high voltage lead that can be bad.
Don't forget to check the spark arrester screen on the muffler.
Mar 05, 2015 | Garden
Umk425u honda trimmer
You have to remove it and manually clean it from the inside by removing the screw on the top. It will be easy to reassemble since it has only one moving part.
Oct 26, 2013 | Garden
I have a ryobi lawn hornet mk.111 and I need the cover that goes over the carburetter is it still available?
http://shop.ebay.com/i.html?_nkw=ryobi+cover+&_cqr=true&_nkwusc=roybi+cover&_rdc=1
Apr 03, 2011 | Ryobi Garden
How do I change a stihl bushcutter/ strimmer blade. ,model fs65
Here is a manual for a model very similar to yours. Please see pages 25-27. Instructions with diagrams are here:
http://www.stihlusa.com/stihl_ownersmanuals/FS55_Manual.pdf
Nov 12, 2010 | Garden
Need exploded view diagram for a zama carby on a ryobi scorpion whipper snipper
www.zamacarb.com
Zama has a great website. It will show you where to find the series and model number of your carb, as well as a search engine to find the diagram and parts illustration for your carb.
Nov 04, 2010 | Ryobi Garden
Ryobi Weed Hornet RWH1100 Mk 11 - carby diagram required.
had similar problems with my mum's 77. she was going to throw it out so i adopted it. turns out i just needed to adjust the injection screw. couldn't tell u where it is as i did it five years ago but armed with the knowledge that carbys have them and a bit of dissassembly i was able to fix it pretty easily. still runnin great now till the starter mechanism stuck. time to pull it apart again, hence my visit to this forum....
Mar 12, 2009 | Ryobi Garden
Garden Logo
46 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
