Question about Garmin GPSMAP 4208 GPS Receiver
NO GPS SINCE UPGRADING SOFTWARE - Garmin GPSMAP 4208 GPS Receiver
How to upgraid my device?
If you're refering to upgrading your Navigation software, QuickGPSfix data and/or your current (out-dated) map, you can do it by connecting to the TomTom website (www.TomTom.com) using the TomTom HOME or MyDrive Connect software, depending on the model/version of your GPS device.
If you're refering to upgrading your GPS hardware/equipment, to have more capability/features, the device is not hardware upgradable, except for adding/using an SD card with a higher storage/memory capacity (to store more info/maps, etc.) ... provided you have a GPS device with an SD card slot.
You'll want to consider buying a newer model with more capabilities / features than what you have now.
May 21, 2016 | Tomtom XXL GPS
Recently my Garmin freezes often, and it takes a while before it works again
Try resetting the Garmin - first a system reset and try again. Then a user data reset and try again.
If nothing helps, try upgrading to the latest software version.
Jun 21, 2011 | Garmin Nuvi 465T Car GPS Receiver
My Finedrive 350 needs upgrading
There are many forums online that have insturctions for "unlocking" gps devices and allowing you to choose which software to install. If finedrive does not have an update - other software might.
austech, gpsu etc
Feb 19, 2010 | Fine Digital FineDrive 350 GPS Receiver
We have a tomtom GO510 and we called and the person said our software needs upgrading and she said there would be no charge for this
You need to go to the TomTom web site and register, then you can download the necessary software install that and THEN & only then connect up your GPS, with the USB cable, & turn on. Then you will be able to update it. Via the internet.
Feb 11, 2010 | Tomtom GO 510 GPS Receiver
No info is showing on screen only reads ''GARMIN''. What can should I do to recall map info.
I recommend upgrading your system software to the latest version. Overwriting this firmware can restore full functionality to troublesome Garmin Nuvi 885T units.
Nov 13, 2009 | Garmin nuvi 885T GPS Receiver
Garmin Webupdater not finding internet connection
I recommend upgrading the system software of your Nuvi 885T GPS to the latest firmware. This link will give you instructions and locations of the files you need to update your Nuvi 885T GPS without using Garmin Webupdater.
Oct 06, 2009 | Garmin nuvi 885T GPS Receiver
I tranfert bluechart from my PC using mapsource to
I recommend upgrading your system software to the latest version (5.30),
follow this link for directions and the file's location.
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
  5. Load the SD card into your GPSMAP 545s and turn it on to replace the system software of your unit.
I hope that helps.
Jul 04, 2009 | Garmin GPSMAP 545s GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Garmin GPSMAP 4208 GPS Receiver Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
