Question about RCA Home Theater Sound Bar - RTS735
Rts735e remote not working
Unit works manually but remote don't . Replaced battery
Where can I get an owner's manual for unidentified air conditioner?
look on cover or inside cover of unit for id tag or a control panel then use that information to look up on line for a user manual or order one ---when ordering remote what information was used to get a correct on --should be able to find unit information from remote like as to what unit it goes to
Apr 18, 2017 | Heating & Cooling
Just bought Topfield TRF2100, screen on and says"installation", but remote won't work.
Be sure there are fresh batteries in the remote. Be sure they are installed correctly and that there is nothing covering the remote's battery contacts. Look to see if there is a film covering the remote's infrared lens or the receiving unit's eye. Check your manual to see if you need to program the remote to the unit. if it's a multi-unit remote, be sure that you have set it to control the specific unit you're working with.
Jul 17, 2015 | Televison & Video
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
Remote no longer works for craftsman opener model #139.53674SRT1 and don't have manual to figure out how to reprogram it.
First make sure the battery is good. Locate the smart/learn button on the rear of the motor unit. Press and hold the button on the remote and then press and immediately release the smart/learn button. If the remote still works it will be programmed.
Aug 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
Saab 1998 wont start
Since you changed the battery .. the key needs to re-sync with the system.
According to some web searches the following may work:
  • Put the key in the ignition
  • Then hold the unlock button down on the key for a minute, while the key in the ignition
Let us know if that works
Jan 25, 2018 | 1998 Saab 9000
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
RCA Home Theater Sound Bar - RTS735 Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
