Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Hp 2575 cuts bottom half of line
Some lines are fine but every third or forth line prints only top half of line
SOURCE: Printer only printing top half of line
I switched my printer off at the mains and back on and this rectified the problem
Posted on Nov 18, 2008
rickyostrom
  • 270 Answers
SOURCE: HP 2355 printer / cutting off the top half of the first line when printing
Do a print head cleaning routine.
Find HP Support here,,,,
http://h10025.www1.hp.com/ewfrf/wc/product?product=422000&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
leroyal
  • 2120 Answers
SOURCE: Cutting off top of line of print but only an occasional line.
Cart is Dried up inside
Posted on Feb 17, 2009
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
  • 4 Answers
SOURCE: My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
Posted on May 26, 2010
Testimonial: "thank you i still have issues i copied a picture and i stll had the problem white lines accross the entire page horizontally about 1 inch apart 11 of them"
HP Officejet 5600 All-in-One series
Is your question the top or bottom one? You have cleaned the metal contacts on both the cartridge and on the machine with a soft cloth, right?
Aug 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Jul 19, 2009 | HP Office Equipment & Supplies
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Nov 17, 2008 | HP Officejet J5780 All-In-One InkJet...
Printer cuts off lines
I had this exact same problem - probably about a week after I put in NEW cartridges. I took them out, wiped the bottom off with a tissue (black and color) and put them back in. Did a test print and everything looks fine now.
Oct 30, 2008 | HP PSC 1610 All-In-One InkJet Printer
Ink problem
I had the same problem. This is what The Geek Squad recommended:
1) Make sure your ink cartridge isn't low.
2) Go to Setup on the printer, choose Tools, then choose Clean Print Cartridges
3) Then, go back to Tools and choose Align Print Cartridges
This worked for me -- good luck
Jul 12, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
23 people viewed this question
Seeker5211
Seeker5211
