Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
BROKEN THROTTLE LEVER ON A RYOBI STRING TRIMMER
HI, MY THROTTLE LEVER ON MY RYOBI STRING TRIMMER BROKE. WHERE CAN I GET A NEW ONE?
THANKS
PHIL
  • dontbother10
    dontbother10 May 11, 2010
    Hello, we are having a problem with self rating by our experts. If you did not rate this or do not believe it warrants a rating of very helpful please rate it as NOT HELPFUL. Experts cannot override your rating and seems to be the only way to stop this practice.
SOURCE: Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Posted on May 28, 2008
SOURCE: ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
Posted on May 31, 2008
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
How to install string for ryobi 50 volt string trimmer
Line Trimmer Line Replacement of a Ryobi One+ 2013 ...
? 2:33
www.youtube.com/watch?v=8jEER8lHUQk
Feb 22, 2013 - Uploaded by TheLegoCityBoys How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
Aug 08, 2015 | Ryobi Garden
I inherited this trimmer and do not know how to add new string. There isn't any kind of a manual that we can find. The trimmer is a RYOBI 137R. Thank you.
hi i have a ryobi rlt 30cd strimmer and when i was useing it it just stopped it as fuel in it but ive cleaned the carb but i still cant get it to run as any one got any ideas thanks
Jul 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Carb screws need adjusted i need to know the settings
Hi. Lightly seat the low screw and bring it out one and a quarter turns. Lightly seat the high and bring it out one turn. Adjust idle screw to suit. Regards Phil.
Apr 19, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
245 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
