Question about Bruder Cat Skid Steer Loader
2005 toolcat 5600 repair fuel tank - Bruder Cat Skid Steer Loader
Where is the fuel filter on Nissan Murano 2005
Hi Firad, IM AL the owner of Big As Auto Repair.
The fuel filter is inside the gas tank mounted to the end of the fuel pump. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Feb 22, 2017 | 2005 Nissan Murano
Toolcat error code 14-03, how do I fix it.
Fuel Shutoff Pull Coil Error Off is the error this forum may be of use to you :) Thread 200 Error code 14 03
Mar 22, 2015 | Office Equipment & Supplies
Bmw x5 fuel gauge doesnt report fuel in tank
You will most likely need to pull the fuel tank out and replace the fuel module.
Apr 08, 2014 | 2005 BMW X5
2005 dodge ram 1500 repair
remove a fuel hose under the car from the pump and siphon the fuel out of the tank
Apr 06, 2014 | 2005 Dodge Ram 1500
Filled truck up with fuel and fuel guage stoped working
There is a TSB for this issue ( TSB 08-2-9 ).
The problem is high sulfur content fuel will cause a problem with the fuel level sending unit, and cause it to read incorrectly.
The 2 times I had this happen, I was not at my normal brand fuel ( had it happen with Shell fuel both times ).
I fueled at 1/2 tank with my normal brand, and then after another 1/2 tank fueled again, and the problem went away.
If you want, the TSB lists new revision fuel level senders, that you can drop the fuel tank, and replace your exiting one with to cure the problem.
The correct P/N depends on your truck cab & bed config, and options
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132 WB
8L3Z-9A213-F Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139 WB
8L3Z-9A213-G Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-H Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163 WB
8L3Z-9A213-A Kit - Fuel Sender 2004 through 2008 - Gas-26 Gal Tank - 126/132 WB
8L3Z-9A213-B Kit - Fuel Sender 2004 through 2008 - Gas-30 Gal Tank - 139 WB
8L3Z-9A213-C Kit - Fuel Sender 2004 through 2008 - Gas-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-D Kit - Fuel Sender 2004 through 2008 - Gas-36 Gal Tank - 145/151/163WB
Aug 20, 2010 | 2004 Ford F150
Fuel gauge is erratic. When tank is full, it reads empty. Eventually it settles in to more accurate reading?????
the problem is with your fuel level sensor. it is in the tank and at certain spot it loses its signal so you read empty. only fix is to replace the sensor.
Feb 16, 2010 | 2005 Chevrolet Trailblazer Ext
I am trying to locate the fuel filter for a 2005 ford explorer on the vehicile itself
  • COMPONENT LOCATIONS RESULTS
Fuel Filter 1995 Plymouth Acclaim 2.5L TBI SOHC 4cyl The Fuel Filter is located: Under vehicle, passenger side, below seating area, passenger side of fuel tank, mounted on chassis in fuel line
Jan 25, 2010 | 2005 Ford Explorer
2005 Mustang GT
Repair or replace the sending unit in the tank.
Jul 28, 2008 | 2005 Ford Mustang
Fuel in my van
Im having a similar issue except sometimes i can fuel up and sometimes i cant. Have you tried fueling up again with out issue
Jun 04, 2008 | 2005 Dodge Grand Caravan
Bruder Cat Skid Steer Loader Logo
32 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
