Question about Canon Office Equipment & Supplies
How to replace drum
How do I remove and replace the drum on a Canon GP 200S copier?
Remove three black screws on side of cartridge. Pull plate off while guiding the drum retainer out of the end of the drum. Reverse procedure to put new drum in place.
Posted on May 19, 2009
Canon gp 335 canon, kako resetovati i vratiti brojcanik na 0, kada je zamenjena web traka
Pošaljite email na koji Vam se mo?e poslati service manual. Resetiranje se radi u servisnom modu.
Jun 02, 2010 | Canon imageRUNNER 400S Copier
I have a canon gp200 copier. while getting a photocopy one side of the document get lightened. can you suggest me to solve the problem.
Hello sir; I would like you go to clean up the charge and discharge corona wire ( right under the drum unit on the machine) with alcohal and Q-tip.
Jan 10, 2010 | Canon GP-200 All-In-One Printer
How to remove drum scretch from Canon 6045 Copier
you cannot fix a line of a drum. If the drum is causing a line on copies you have to replace it. Any light or fingerprints can cause further problems. Look online or at your local canon dealer for the drum unit.
Oct 12, 2009 | Canon NP 6050 Copier
ERROR 000 GP 200
its a fusing unit filment problm try to replace the filment or replace the film unit
Jun 05, 2009 | Canon Office Equipment & Supplies
DO NOT REMOVE THE CANON GP 555 DRUM
It is easy, open the front door and fold down the transport unit & the drum is to the left of the developer aunit. There is one screw that hold the drum in, unscrew it and before you pull the drum unit out remove the grey filter unit to the left of the drum, then remove the drum unit. Note there is a corona wire as the primary charge, it is not a roller. There is a screw that holds the unit in on the rear of the drum unit and also, there is one silver secew that is attached to the cleaning unit for the post corona wire. Some C.Q. problem can be fixed with replacing the post corona wire. Good Luck
Nov 19, 2008 | Canon imageRUNNER 400S Copier
Canon gp 200 error code EO10
that is a main motor drive error code either you have a bad motor or something is locking up
Aug 28, 2008 | Canon NP 6650II Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Erreur
I'm not too familiar with your machine. Its a bit before my time, nut from the info that I have, the problem is with the finisher. I would suggest that you get a canon technician out to have a look at it.
May 09, 2008 | Canon imageRUNNER 400S Copier
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
121 people viewed this question
old marine
old marine
