Question about Oster Blenders
Oster kitchen center is stuck in down position
The mixer is stuck down with the attachments in the bowl. It will not release and go up.
3 Suggested Answers
SOURCE: replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
Posted on Feb 28, 2008
  • 10 Answers
SOURCE: oster kitchen center 5500-08a
I have not seen this problem with ours yet but if turning up the speed doesn't help (first thought would be the motor's overloading because you're using hard foods in it on a low setting). If it shuts off even under light loads, judging by the manual it's something you need to send it in for. See if there's a service center in the area. These Kitchen Centers aren't made any more and it's unlikely you can fix it yourself.
Posted on May 04, 2011
Any ideas how I remove both the mixing bowl & blade that won't release from my hardly used (maybe 10x's) Kitchen Aid Food Processor?
It sounds like the blade has become jammed on the motor shaft sleeve. You will be up for a new blade and motor shaft sleeve to sort that out. They are not expensive and it is the only proper fix for them. If you replace nothing it will happen again pretty much straight away and if you only do one the other damaged part will wreck the new part. To solve the not turning on problem which is a separate issue it will very likely involve replacement of either the bowl or the lid. One is as likely as the other, I have both parts in stock so I try one or the other to decide which one is the problem. Getting the blade off is a real chore, I have a small chain (with welded links so very strong) I put a couple of turns around the big blade shaft and fix it there with a shackle. It's about 2.5 meters long so I attach the other end to the leg of my bench and accelerate the motor unit away from the bench. The chain comes tight and shocks the blade off. I then drill a hole through the motor shaft about 8 mm from the top, attach the chain to that with a shackle and shock it off just like the blade. New parts now and job done.
Nov 20, 2015 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Stuck
The problem is: when last used, the contents of the container may have spilled over and seeped into the tab switches along the interior well of the unit. The tabs will not release the container as they are STUCK. Try a spry mist of window cleaner around the base of the container and let sit a short time. Try to move container around several times and see if it releases. It will not come out easy, and if forced, the entire unit will be damaged. Also, the hard rubber connector that engages under the container can become misaligned and when off center, it will bind up.
Mar 02, 2014 | Oster myblender:Personal Blender:Ships...
I have osterizer food grinder( Detouchable) but machine was lost where can i find a replacement for the machine...
If you mean the one that attaches to a Kitchen Center, they are no longer available, eBay or garage sales are your only hope.
http://www.ebay.com/itm/OSTER-REGENCY-KITCHEN-CENTER-MEAT-GRINDER-ACCESSORY-/270805020990
Same with the free-standing models they had.
Sep 12, 2011 | Blenders
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Oster kitchen center 5500-08a
Sep 23, 2008 | Oster Blenders
Replace oster kitchen center base drive part
Feb 11, 2008 | Blenders
Blenders Logo
41 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
