Question about Motion Computing Motion LE1700 Tablet PC - Intel Core Solo U1400 1.2GHz - 12.1" SXGA+ - 1GB DDR2 SDRAM - 30GB - Wi-Fi...
Motion Computing Motion mc-c5 Tablet PC - Intel Core Solo U1400 1.2GHz - 12.1" SXGA+ - 1GB DDR2 SDRAM - 30GB - Wi-Fi...
2 Suggested Answers
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
Hard drive disappeared
this is a common problem on these le1700's. Can you hear the micro drive spinning up when you turn on the tablet? If you hear clicking the drive may have gone bad. If the drive is heard spinning up and doing normal whirr's and clicks it may be the connectors need to be reseated on the drive. Opening the panel for the drove and removing the 4 screws allows you access to the drive and the delicate ribbon cable attached to it. Carefully reseat the drive, or have a person that knows about zif (zero insertion force) drives reseat it for you. If it's still not working it's possible the cable itself went bad. ONLY OEM cables seem to work on these- the aftermarket ones are iffy. Also they type of drive seems to be important as well- Toshiba or Hitachi micro drives are o.k., but a micro ssd ziff seems to have less compatibility issues in my experience.
Apr 17, 2013 | Motion Computing Motion LE1700 Tablet PC...
How to unlock my tablet pc
for me to be able to give you this information i will need to know the maker of the tablet and model
Dec 20, 2012 | Lenovo Intel Centrino Pentium M 778 1.6GHz...
Cambiarlo al idioma espanol
en la pagina principal debes de ver lo que parece a engranajes o herramientas. (settings). Selecciona eso y selecciona el septimo opcion para los ajustes generales. (general). el
duodecimo opcion (num. 12) y selecciona espanol
Nov 20, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Desbloquear tablet pc m778
alguien me puede decir como desbloqueo mi table pc android
Mar 14, 2012 | Lenovo Intel Centrino Pentium M 778 1.6GHz...
My power slide button on my motion LE1700 does not power up my tablet, this is my second one this has happened too. I have sent if off for fixing and last time they charged myself 400pounds for a complete...
those are generic B.S. answers. The power switch is a flat tab that has two prongs on the rear side that interface a very small slide switch on the mother board. The mini slide switch has a plastic piece that sticks out about 3mm and the plastic part is unfortunately not very strong. the slide return spring may have become detached as well- this indicates major trauma to the slide switch in some way- and the repair is expensive because the parts are not readily available- hence the 400 price tag for a whole new board. Nowadays these tablets are dirt cheap. I'm guessing by how old this post is you have moved on to a newer tablet- if not I'll work with you to get it fixed- at a lot less as well.
May 19, 2011 | Motion Computing Motion LE1700 Tablet PC...
My motion computing battery light is not on and the machine won't start
Hold down the power button for 10 seconds then release. Then try pressing the power button again.
Apr 26, 2011 | Motion Computing J3400 Rugged Tablet PC...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Starts up and freezes anything can I do
probably the CPU is getting too hot. Is the CPU fan working?
Mar 17, 2010 | Microsoft 3K RazorBook 400 CE Ultra-Mobile...
Freezes up and nothing works. Mouse does not move.
Sounds like it's time for you to reformat the drive and re-install windows.
Sep 24, 2009 | Microsoft 3K RazorBook 400 CE Ultra-Mobile...
Motion Computing Motion LE1700 Tablet PC - Intel Core Solo U1400 1.2GHz - 12.1" SXGA+ - 1GB DDR2 SDRAM - 30GB - Wi-Fi... Logo
29 people viewed this question
Top Motion Computing Tablets & eReaders Experts
jason
k24674
Chris Larocque
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
