Question about Kicker Car Audio & Video
Red light on no sound
Ix 450d
WHIRLPOOL WBM35 IX LIGHT NOT WORKING
Check door switch lite will have a switch on door can maybe just a wire off
Jun 29, 2015 | Whirlpool Refrigerators
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
My xbox ix switching on and shows three red rings and after 5 minutes the brick turn orange and it now has two red rings whay do i do to fix it
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Jan 10, 2013 | Microsoft Xbox 360 Console
Can't switch on the camera
I think the charger of the camera might be your problem maybe you'll have to buy a new charger goodluck:) and please rate this solution...
Jun 06, 2010 | Canon EOS 450D / Digital Rebel XSi Body...
Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Nov 28, 2009 | Ovens
Compatibility of cullman cx35 with canon 450D
It shouldn't hurt the 450D: you won't be able to use TTL mode.
Aug 21, 2009 | Cameras
My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
May 16, 2009 | Canon EOS 450D Digital Camera
Three red lights . Freezing
This means your xbox 360 is dead you cant ix it on your own you must send it away to microsoft to be repaired if it is still under warranty then it will be free but if the warranty has end then you will have to pay to have it fixed.
May 08, 2009 | Microsoft Xbox 360 Arcade
Car Audio & Video Logo
11 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
