Question about LG Shine KE970 Cellular Phone
Ke970 keypad does not work..is there a keypad lock or unlock for this phone ?
  • Anonymous Mar 19, 2014
    So theres no way on earth u can unlock keypad lock on phone atalll found iphone on train
    Sergeant:
  • 452 Answers
  • do keypad settings:
  • go to main menu<settings<security settings<select keypad settings< here u wil get the option for locking or unlocking keypad
 otherwise there might be  some problem with the keypad for this u need to contact LG care center.
Posted on Oct 23, 2007
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
I forgot the keypad lock of my n3110c hoe do i unlock it
long press unlock key , when appears "now presss *" then press *. and ur code will broken.
May 04, 2009 | Nokia 3110 Cellular Phone
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Lock the keypad
K800i To manually lock the keypad:
  2. Select "Lock keys".
  1. From standby, select "Menu" > Settings.
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
Unlock pantech c3b
Lock or Unlock the Pantech C3b Goal:
Lock or Unlock the Pantech C3b Fact:
Pantech C3b Fix:
Pantech C3b Keypad Layout
Keypad Lock
The Pantech C3b does not have a Keypad Lock feature. When device is not in use, close the flip to guard buttons from accidental contact.
Lock the Phone
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and highlight Phone Lock.
  5. Press the directional pad left or right to select Enabled.
  6. Press OK.
  7. Enter the Password.
  8. Press OK.
Unlock the Phone
  1. From the standby screen, press Unlock.
  2. Enter the Password.
  3. Press OK.
Aug 26, 2008 | Lands Phones
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
LG Shine KE970 Cellular Phone Logo
386 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
