Question about Hitachi RAS-09UH Air Conditioner
Remote reset How to set date and time
How do i bypass cmos battery
You need to have the battery in order for system to boot, however, you can reset it.
http://www.howtogeek.com/131623/how-to-clear-your-computers-cmos-to-reset-bios-settings/
How to Clear Your Computers CMOS to Reset BIOS Settings
Oct 06, 2016 | Computers & Internet
I have an old sanyo analog vcr and I need to set the time and date
You will need the remote for that. Select the main menu, then look around for time setting option. You will probably have to use either the arrow keys or numbers on the keypad of the remote to set the date. Some models will have an OK button to set the date/time on each part. If you see an auto setting for the clock time, set it to off, as broadcasters no longer set a time out for analogue models.
Oct 05, 2016 | Sanyo Televison & Video
My new 40" LED tv does not remember the time /date and is constantly asking to set up the input devices.
Just make a hard reset to this set and try. Refer its user manual for details.
Jan 23, 2013 | Televison & Video
I Need to update the time and date on my vmax flex DVR
Hold down the OK button on the remote for 30 seconds. Screen will ask you to reset password. DONE!!
Jan 19, 2013 | Digital Watchdog DW-VF16500G VMAX-FLEX...
The Date and Time change back to installation date and programs no longer work
if you have a 4 button spa side remote unplug and see if it continues its called ghosting if so replace controller
Dec 10, 2012 | Jandy Aqualink RS8 Pool/Spa Combo Control...
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
My remote only show years through 2009, I connected it for updates which it loaded several of, but didn't update the year
the harmony remote updates most of its date and time settings from the computer.
see what the date and time is set to. if its wrong, fix it then update the remote.
Jan 31, 2010 | Logitech Harmony 890 LCD Remote Control
Ativa at-p3000 adding machine....no user manual or way to set ate and time
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
Dec 14, 2008 | Computers & Internet
I cannot set the time, my 880 remote want allow me to set the time!
I saw these posts recently and decided I would try and figure out the time on my Harmony 880.
First, using your Logitech Harmony remote software, version 7.5.0, log on using your login ID and password.
Next, select the remote settings tab, and go to display settings. Select time/display format and check the 24 hour format. (Note: the assumption is that you have already set the 12 hour time before hand, even though is says A.M.) I made this change to my own remote when it was actually was 7:30 P.M.
My remote actually reported 7:30 A.M. at this point. Save your changes online and plug in your remote to your USB port and let the Harmony update your change. Now your remote should be in 24 hour format.
Finally, log back on using the same procedure above only this time, click the check box for 12 hour format, save your changes and update your Harmony 880 one last time. Your finished, your remote should now be displaying the correct time in 12 hour format.
Oct 14, 2008 | Logitech Harmony 880 LCD Remote Control
Hitachi RAS-09UH Air Conditioner Logo
20 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
