Question about Ricoh 885400 Aficio 885400-C Black Toner For Ibm Infotec Copier
Copy machine screen fade
Copier screen fade after I cleand it using a wet towel!!
    Habit-Forming:
    New Friend:
  • 104 Answers
Check the side of the screeen (left side) u will see a nub like a volume conrol nub , use it to adjust the screen density
Posted on Jun 05, 2014
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Posted on Jan 27, 2009
Tip
How to clean your screen (TV-Laptop-Monitor)
LCD and plasma screens have a anti-glare coating or anti-reflective coating. This is so any bright light doesn't reflect and wash out the picture. It does help but it also makes cleaning the screen a bit of a problem.
As this is a coating on glass it is actually possible to clean t off by using the wrong cleaner. There are great glass cleaners out there but most are chemically based and too aggressive. In other words they attack the coating.
So what do you use? Paper towels, a drop of dish washing or liquid soap and water. And you need to use a bit of a technique or you will see smears or smudges on the screen.
You need to get two sheets of paper towels. One is your dry wipe. Wet one with water. Then add a drop of liquid soap or detergent. Give it a couple of gentle squeezes to distribute the soap. Then give it a bit harder one to get rid of excess water. Depending on the coating you may want a second piece that has only water and just damp not wet.
Now we clean the screen. First take the soapy towel and wipe down the screen getting it wet. You don't want running water just enough to wet the screen. If you have the soap right you will just see the odd bubble. Once you have the screen wet, wait about 30 seconds and now scrub it using the soapy towel with a circular motion. If there is anything on the screen it should come off. If something is stubborn just keep scrubbing it or use a fingernail to scratch it off and wipe with the soapy after.
Now we need to get the soap off. If the screen dries and has streaks you may need to use the wet un-soaped towel to wipe/rinse of the soap before drying. To dry the screen we want to use the dry towel and use large circular motions. Go over it once and turn it over so the dry side is being used. Keep using those big round motions and at the same time ease up of how hard you push the towel. The idea is to have little pressure on the towel as you finish. That's the trick to getting it streak free.
This takes a minute to do but lets you safely clean your display without damaging the coatings. It also works on any glass surface.
on Apr 16, 2010 | Televison & Video
Hi my name is Raven, I'm having a problem with my Lexmark z2320 printer. I just replaced the cartrige and it still sends a message to the computer saying that it cannot print due to low ink. How do I...
If LEXMARK printers are anything like LEXMARK copy machines then I may be able to help you. The cartriages sit on the shelf where they are being sold and tend to dry out a little bit. I talked to a fellow about a year ago and he told me to take a paper towel wet it with warm water and hold the copper end of the cartriage to the wet paper towel for a few minutes. Do this till the ink in the cartriage loosens up. It worked when I did it. GOOD LUCK Dannydoesita.
Jul 13, 2011 | Lexmark Z2320 InkJet Printer
Our Sharp AR-160 copy machine is 5 yrs old. We have had to have continued maintenance, most recently the "developer" was replaced and our copies still come out faded. How long should we expect...
Did they clean the laser unit?
You can play with bias to raise the copy darkness.
For start you can open the front door and right side way door, remove drum unit, and you will be able to see long glass above drum unit. clean it with the dry wipe or wet one but be sure to dry it.
By my experience it is a good low maintenance copier... if the preventive maintenance is carried out correctly, every 60 000 copies more or less.
Hope that helps!
Dec 27, 2010 | Sharp AR-160 Copier
How can I get a clearer print? Everytime I print
Beleive it or not, sometimes a new cartridge comes with the ink clogged too, put both color cartridges over a wet towel with windows cleaner by 5 minutes, then clean both with a dry towel, try to print, if the quality print stay bad, you have to suspect the printer cartridge contacts, check if are clean (if you have to clean it, do that with the printer off), if the fail continues try to use the manufacturer warranty
Jul 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 2410 photosmart printer is printing faintly and only bottom half of words in paragraphs. The color is also faint. I have replaced both the color and black cartridges. I have also run head cleand and...
Try taking out the cartridges and blot the bottom of the cartridge with paper towel wetted with warm water.Repeat several times.While the cartdigdes are out, use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridges.
Feb 01, 2009 | HP Photosmart 2410 All-In-One InkJet...
Copier not printing properly
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be  dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the  cartridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10  Seconds......
Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same  way........
Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a  Copper plate on it with small boxes just clean that copper plate with the Dry Paper
Towel..........
Know insert both the catridges inside the Printer........ Good Luck
Jan 28, 2009 | HP LaserJet 3380 All-In-One Printer
PC 920 Faded sides
hi
try this open the copier and remove Toner Cartridges and shake side ways for 5 times and try to make copy,if faded gone its better to replace Toner Cartridges for better copy quality
Dec 12, 2008 | Canon PC-940 Black and White Copier
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Oct 27, 2007 | Xerox 5305 Copier
Ricoh 885400 Aficio 885400-C Black Toner For Ibm Infotec Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
