"Emerson LF501EM4F picture setting with time warner cable box
Coldcut
  • 1554 Answers
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
SOURCE: HDTV Setup
SCREEN TURNS BLUE/THEN DARK/ DVD PLAYS WITH PICTURE/.HAS SOUND...HELP. i AM HOOKED UP TO DIRECT TV.
Posted on Jun 30, 2008
mistersony
  • 320 Answers
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Posted on Oct 18, 2008
SOURCE: Time warner cable box doesnt have a code for maxent mx-26x3
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Posted on Dec 06, 2008
  • 5 Answers
SOURCE: sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Posted on Feb 10, 2009
My tv Emerson LF501EM4F audio went out. The picture and everything else works but no sound. How do I fix it? Thanks.
Based on Emerson reviews, you might be better off buying another (maybe different brand) TV.
Jul 10, 2017 | Emerson Computers & Internet
A RED LIGHT IS FLASHING ON MY EMERSON LF501EM4F HOW DO I FIX THAT PROBLEM
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 26, 2017 | Emerson Televison & Video
Why doesn't my Emerson lf501em4f not recognize cable box HDMI?
Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
Sep 28, 2014 | Emerson Televison & Video
Emerson TV LF501EM4F picture upside down
there's a software upgrade on emerson's site that corrects this problem.
Jan 21, 2014 | Emerson Televison & Video
How to connect philips soundbar to emerson tv
how do i connect a polk soundbar to an emerson LF501EM4F
Jan 10, 2014 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
