"Emerson LF501EM4F picture settings
How to set the picture to 1080dpi and color settings with a two cable box.
circuitcity
  • 137 Answers
SOURCE: yellowish color from DVD
Hello Tsmith4,
Have you tried another source such as a HD cable box on the same component input (Y Pr Pb) By doing this you will eliminate the TV or the DVD player. If the picture shows great using the cable box on that same input then we will assume that the TV is ok for now. You may want to also check the DVD menu under progressive scan that it is set to progressive scan. if the picture is still not good, we would want to look at the I/O board on the TV. The red path after the Video switch maybe open. If this is the case we will have to go to board replacement. I will tell you what board to change.
Best regards
circuitcity
Posted on May 28, 2008
  • 28 Answers
SOURCE: emerson tv with dvd
Go to menu, and turn off all your caption options. This boxes are used for Text transmission. A few years back PBS use to run news briefs, using this option.
Posted on Sep 18, 2008
guitarman002
  • 80 Answers
SOURCE: Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Posted on Jul 23, 2009
eagle338
  • 4889 Answers
SOURCE: set up my 26 inch
Through which input did you connect the cable? RF port, component? Please c;arify this info so that I can help you with your problem.
Posted on Nov 13, 2010
  • 1746 Answers
SOURCE: I set up teac HDB840
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Posted on Jun 18, 2011
My tv Emerson LF501EM4F audio went out. The picture and everything else works but no sound. How do I fix it? Thanks.
Based on Emerson reviews, you might be better off buying another (maybe different brand) TV.
Jul 10, 2017 | Emerson Computers & Internet
A RED LIGHT IS FLASHING ON MY EMERSON LF501EM4F HOW DO I FIX THAT PROBLEM
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 26, 2017 | Emerson Televison & Video
I have a 50 inch Emerson tv model number LF501EM4F had a severe storm came through and now the TV does not work. I believe it's due to a lightning strike. Can it be repaired
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 18, 2015 | Emerson Televison & Video
Why doesn't my Emerson lf501em4f not recognize cable box HDMI?
Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
Sep 28, 2014 | Emerson Televison & Video
Emerson 55" tv. LF501EM4F. The board that has the ext ports (coaxial) , can it be purchased. The cable connection twisted off. If it is available what does it cost and how hard is it to change out. ...
Hi Paul these are very easy to change just be careful when opening connectors, particularly the ribbon cable
Here is a used but tested part I found on ebay for a great price, most others wanted 60-70 dollars but this one is 20 dollars
EMERSON LF501EM4 MAIN BOARD BA31T0G0201 2
May 12, 2014 | Televison & Video
Emerson TV LF501EM4F picture upside down
there's a software upgrade on emerson's site that corrects this problem.
Jan 21, 2014 | Emerson Televison & Video
How to connect philips soundbar to emerson tv
how do i connect a polk soundbar to an emerson LF501EM4F
Jan 10, 2014 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
Wall mount screws for an Emerson LF501EM4F what size?
Take it a good photo, front and rear, might look for mount holes. Measure separation of holes, then go to a home depot and ask them. They know all about how to mount a TV set on wall
Dec 02, 2013 | Emerson Televison & Video
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
