Question about DCS 36 in. CTD365N / CTD365L Gas Cooktop
Stop clicking sound stove
Our DCS starter clicks continuously. How can I stop this?
2 Suggested Answers
  • 205 Answers
SOURCE: DCS 305 cootktop: one
Hello- What is probably happening is that the simmer orifice is clogged. If this gets clogged-up and not enough gas comes out to the burner it will continue to click. This is usually pretty easy to remedy. Take off the burner cap and you will see two holes, one in the center for the main burner and a smaller one that is on the perimeter of the burner. Look down that small hole and you should see a bronze orifice, it is pretty small, about 1/8" in diameter on the outside, looks like a nut. Most likely you will see grease or charred bits on the top of it (you can use one of the other burners for a reference if you are having trouble seeing it clearly) In the center of the orifice is a tiny hole, this is the part that is likely clogged. Now, you'll need to find something really skinny, like thin sewing needle and poke it into the orifice opening. Sometimes it is necessary to hold onto the needle with needle-nosed pliers in order to get it far enough in. Just be gentle with it and if what you are using seems too large in diameter then it probably is, you don't want to dent or cause any damage to the orifice opening. Once you get it cleaned out it should work ok. Let me know if you have any questions. Best regards.
Posted on Sep 29, 2010
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
All five inniters stay on while all five knobs are off,model is ct-365
Hi deq8,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 18, 2011 | DCS CT-365 Gas Cooktop
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
All 6 igniters continue to click after any one burner is turned on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 30, 2011 | DCS CS-366-SS Gas Cooktop
Electric starter won't stop clicking - how to unplug starter?
Your electric spark switches got wet. You may be able to remove the knobs and use a hair dryer through the switch/valve opening to dry them out.
Dec 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
Continuous clicking of gas stove starter
if it stiill click after u put to ignition mode if it starts automatically it could be the pub or manual will be the switch
Aug 10, 2009 | GE Cooktops
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
GE gas stove top igniters won't stop clicking
My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
And, to check the model number, look at the various places pointed to in the upper left of this diagram. http://www.applianceaid.com/newpics/range-model2.JPG
Oct 18, 2008 | GE Profile JGP636 Gas Cooktop
Viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
Aug 20, 2008 | Viking 31 in. VGSU101 Gas Cooktop
DCS 36 in. CTD365N / CTD365L Gas Cooktop Logo
55 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
