Question about E-Machines T3958 (827103050974) PC Desktop
Computer won't turn on
Have the same green light inside but turning it on with the power button nothing comes on is it the power button?
  • 15,935 Answers
Check that the switch on the power supply has not been accidentally bumped.
It should be on the - side... not the o side.
There could be a variety of other problems including the power switch.
Possible reasons a PC will not power up:
Failed Power Button.
Power strip breaker tripped - are there other items plugged in that work?
Failed memory Module.
Failed CPU.
Failed CPU Cooling fan.
Failed power supply.
You will need to test each item with a Digital Multi Meter (DMM) and verify 12VDC at each item. CPU and Memory can only be tested externally by a shop with a reader.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 18, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
this is only a guess sally yoour PSU need to be replaced.
Apr 09, 2013 | HP Omni Pro 110 XZ822UT AllInOne
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
E-Machines T3958 (827103050974) PC Desktop Logo
229 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
