Question about Maytag Washing Machines
New HE washer not draining on spin and drain
On my new washer, the spin and drain leaves clothes soaked. What could be wrong?
Load was too light, needed to add a towel in order to wash nylons. I will be hand washing from now on. Washing machine doesn't do delicates to my satisfaction.
Posted on May 19, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Sometimes washer will not drain completly. leaving clothes soaked after spin cycle. sometimes suds also remain.
either discharge hose is stopped up or washer drain pipe backing up or possible water pump on washer going bad but i would really lean towards the hose or drain to the washer
Jan 23, 2011 | Kenmore Washing Machines
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Sometimes the top load clothes washer will not spin very fast and not all the water will com out. This leaves the clothes still soaking wet. What causes this???
over loading too often, belt slipping from ware needs replaced. could have kinked drain hose or debri in pump could make it take too long to drain and stops before it has a chance to spin
Dec 21, 2009 | Magic Chef Dryers
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
