Question about Paragon GENERIC REPLACMENT MECHANISM 110V SPST - CD101PC
Model 4003 00 timer
I have a pool sweep paragon 24 hrs timer (4003-00) which has worked well for 35 years. all of a sudden the timer wheel motor does not work. I opened the wriring. There was corrosion, I clened them up but nothing happened. Are there fuses involved? is there anything else, short of buying a new one, that I can do?
  • Paragon Master
  • 5,089 Answers
  • 52 Answers
SOURCE: Paragon timer parts
electricalexpeditors.com
Posted on Oct 05, 2009
  • 52 Answers
SOURCE: My timer won't cycle the motor on and off.
you may need trippers
Posted on Feb 26, 2010
  • 760 Answers
SOURCE: why does the motor on my paragon 24 hour timer
How old is it? Most of these timers have two leads that come down to the terminals. This powers the timer motor. Check to be sure these terminals are tight. They are workhorses, but dont' last forever. They make electronic ones now too.
Posted on Jul 01, 2010
SOURCE: I need a replacement mechanism
1) Paragon is no longer making timers and parts except defrost timers.
4004-71M is not defrost timer.
2) Manual shows 4004-71M is DPST 40 amp 240Volt timer.
4000 series is 24 hour repeat timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
3) To buy replacement timer, Intermatic crossover guide shows T104M used for pool and spa controls and to replace timer mechanism
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
T104M at amazon
http://www.amazon.com/Intermatic-T104M-Mechanical-Mechanism-208-277/dp/B001DNYMV6
4) Or you can buy T104 with Nema1 indoor box, or T104R with Nema3R outdoor box
Googel search model number for vendor
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
5) How to wire T-104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
do-it-yourself project.
Posted on Jan 14, 2011
SOURCE: Is it possible to buy the timer motor for a
1) Paragon is no longer making timers or parts except defrost timers.
7008-20 240V 24-hour mechanical timer is not a defrost timer.
Link below shows folks who might still have Paragon parts
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
2) To see Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
3) If you want to buy new timer: Intermatic cross-reference guide shows T7802B is correct replacement timer
4) Electric supplies online shows T7802B 4 pole 2NO/2NC
http://www.electricsuppliesonline.com/int7tidp20t.html
5) Manual for T7802B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7802b%20-%20english.ashx
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 09, 2011
Looking for set of trippers for paragon 4014-20 pool timer
Copy following link to identify timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Paragon 4000 series uses X2772 tripper
Paragon is no longer making timers except for defrost times.
There is a new line of timers coming from China that looks identical to Paragon 4000, and uses same tripper. As a result this timer design and trippers could be around for years to come.
Replacement timer is Intermatic T104R 240Volt indoor outdoor enclosure, with replacement parts widely available
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Add a comment
Apr 03, 2013 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Need trippers for older unknown model number amf paragon pool timer. timer is 15 - 20 years old
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Jul 21, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I have the 7007- 00 > 24 hr 7 day timer, but only have 1-off and 1-on timing wheel tripping set screw . I need 6 more of each type (on/off for each day) I'm using the timer to operate a 1 hp pool...
Paragon 7007-00 120Volt 7-day timer with 4-NO terminals uses X4299 tripper.
Paragon is no longer making timers and parts, except for defrost timers. 7000 series is not defrost timer.
Patriot supply shows the X4299 tripper for $15 per pair July 2011.
Open following link to identify timer:
Intermatic cross-over timer is T7401B
Jul 14, 2011 | Paragon 7007-00 Electromechanical Indoor 7...
I am looking for a source to replace timer motors and silver contacts on a bunch of paragon 8025 24 hour timers.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
According to e-mail I got from Paragon in Nov 2010, Paragon is no longer making timers and parts.
Except for defrost timers.
I don't know how narrow the Paragon defrost line has become, if they still making their commercial refrigeration timers, or if they're just making smaller refrigerator defrost timers.
Or if Paragon has parts for the 8025
http://www.uni-line.com/common/custserv.aspx
Jan 12, 2011 | Paragon 8025-00 Enclosed Indoor 24 Hour...
I need a replacement mechanism for a Paragon 24 Hr timer control Model 4004-71M.
T104M at amazon
Jan 07, 2011 | Paragon Vintage 24 Hour Timer Command 12...
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Paragon GENERIC REPLACMENT MECHANISM 110V SPST - CD101PC Logo
125 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
