Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
Westinghouse ld-2480 television screen is blank when turned on
The power is plugged in and the screen light is red and the television screen won't come on
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
  • 10 Answers
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Posted on Dec 31, 2009
budmrtn
  • 11361 Answers
SOURCE: my westinghouse w33001 flat screen tv keeps
It is shutting down may be because of bad power supply or shorts circuits in the backlight inverter board. You will need to do in-depth troubleshootting to narrow down the problems.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 19, 2010
SOURCE: Westinghouse LTV32W6HD 32 in This television
Based on the symptoms you are describing it seems like your T-Con board is going bad. This board is located on top of the panel and its main function is to make the pixels properly display on the screen. When this board goes out you can experience a few things and normally red or blue spots in the dark areas is one of them.
Posted on Sep 11, 2010
westytech
  • 120 Answers
SOURCE: We were changing channels on Westinghouse
This sounds like the inverter board has gone out. The inverter board is in charge of turning on and off the back light. If this goes out the TV is still able to fully function meaning you will still get power indicator to turn on, but since the back light is off you cannot see anything on the screen. You will need to replace this part so your TV can be fully functional again. For more information on how to replace, obtaining the correct part #, and parts as well as price availability please send me a quick email to westytech@westinghousedigital.com. Please rate this comment if it was useful.
Posted on Sep 29, 2010
How do i find the power supply
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 30, 2015 | Westinghouse Televison & Video
Westinghouse LD 2480 wont power up
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 30, 2015 | Westinghouse 24" Class 1080p 60hz LED LCD...
I have a 24 inch White Westinghouse TV model #ld-2480 when I turn it on the blue light comes on then it goes out by itself
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Televison & Video
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
Jan 30, 2013 | Westinghouse Televison & Video
Power adapter
http://www.ebay.com/itm/AC-Adapter-4-Westinghouse-LD-2480-24-LED-HDTV-TV-Charger-Power-Supply-Cord-PSU-/261042434846?pt=US_Monitor_Power_Supplies&hash=item3cc757731e
Aug 13, 2012 | Televison & Video
Code for Westinghouse LD 2480 LED TV
Look at the back of your remote... It should give you a simple fix... WORKED FOR ME!!!
Jan 18, 2012 | Westinghouse Televison & Video
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
41 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
