Question about Hitachi (hts545050b9a300) 500 GB SATA Hard Drive
Hd wont mount - Hitachi (hts545050b9a300) 500 GB SATA Hard Drive
Did a system recovery and now it wont load properly..is stuck in a loading apps loop.
The install is checking for more information and applications. It is not able to locate them. Are you sure about the make and model?
Jan 26, 2016 | Ematic HD Quad Core 7" Tablet 8GB Memory...
What size screws do I need to mount the VESA to the back of a 39" Vizio?
Most flat screens use 4, 6, or 8mm, be careful not to use too long a screw.
Aug 08, 2014 | Vizio 39" Class 1080p 60Hz LCD HDTV - Full...
Prestige 10 tablet wont read NTSC
It may just not be mounting the storage. Connect the HDD to the tablet. Go into settings > storage and look for a mount option for usb storage. Click that. Then if you have a file explorer program such as ESExplorer you can browse the usb storage.
Dec 08, 2012 | Visual Land ME-110-16GB-BLK - Prestige 10...
Best wall mount for sylvania 6842thg plasma
To make it simple: Mounts go by the size of the TV.
You have the choice to get a standard mount that can only swing or a mount that can swing and tilt or even extend. Plasma TVs are a bit heavier, than LCDs therefore, you need a solid mount. There are wall mounts and ceiling mounts. Mounts can be purchased from Home Depot, Lowe's and best buy, they can also be bought on line. If you buy it from a local store and does not fit, you can take it back the next day, an option you wont have if you buy online.
Good luck
N Sabre
Nov 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Hi, I have a Seagate 7200.7 External HD that won't mount anymore. I saw there where some possible solution by connecting it on Com2 on a Windows 98 based PC but needed special HW, is there any possible SW...
please remove the drive from the casing and mount it directly to your pc first through an interphase , if its sata just power it and connect the cable to sata connector in the mother board , i feel your drive will be mounted ... it means your interphase used has lost its rom information
if the drive still doesnt mount , then it has lost its firm ware and its usually the cert module of firmware.please pm me if you wont find any solution
datarecoveryfactory
Sep 06, 2009 | Computers & Internet
My hd 500 won't mount. CD Part is recognized,
YOu should try a shorted _SCREENED_ USB cable it sounds like this is faulty
Aug 09, 2009 | Acomdata 500GB External Firewire HD 500 GB...
ERROR
HD detection error: the HD cannot
be detected; the machine fails to turn
ready; an error state is returned.at time of Bootrom
processing, BARSAC is started up and
mounted (usrIde).
[Timing] once at power-on
Jul 28, 2009 | Canon imageRUNNER 7200 Copier
DVD s to HD
Hi!
Its not that easy as is sounds to do that.
First of all there is probably some protection on the dvd that wont allow you to copy it, therefor you need to crack that protection
Second, you need to remake that dvd to an "img" file, the dvd contains two folders as it is now, one called Audio TS and one called Video Ts, you need to remake those to an IMG file, that you can do in Nero
Third, you need a program to mount up the IMG file so you can play it, for that you need a program like Deamon Tools or any similiar program.
So if you manage to do all above, every time you going to play that dvd you must mount it in Deamon ( or any similiar program), you cant just copy it and press play and watch it.
The hard thing is to crack the protection on a dvd since there is so many diferent of them out there.
Good luck
Nic
Apr 08, 2009 | Microsoft Windows XP Professional SP3 Full...
Hitachi (hts545050b9a300) 500 GB SATA Hard Drive Logo
21 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
