Question about One For All URC 8780 Remote Control
Code search - One For All URC 8780 Remote Control
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
I have a oleia tv im trying to program my rca rcu403 but it wont work
your oleia tv code is 1610 OR 1240 OR 073
In order for the 3 component universal remote to control your TV you must program it with the TV code
that matches your TV These instructions explain the preferred method of programming the remote the
Direct Entry method 1 Manually turn on the TV
2 Locate the enclosed TV Code List. Find your brand of TV
Note If your brand isn t listed, use one of the Code Search methods to
program this remote control See Code Search on page 24
3 Press and hold the CODE SEARCH key until the indicator light
illuminates Then release the CODE SEARCH key
4 Press and release the TV key The indicator light blinks and then remains lit
5 Use the number keys to enter the first code listed for your brand.
After you enter a valid three digit code, the indicator light turns off
Note If you enter an invalid code the LED will flash rapidly for 2 seconds
Start over at step 3
6 Aim the remote at your TV and press the ON OFF key If your TV turns off
you have found the correct code
7 Enter the code in the box provided on this page for future reference.
8 If your TV doesn turn off repeat steps 3 6 above entering the next code
for your brand.
If none of the codes work or your brand is not listed use one of the Code
Search methods to program this remote See Code Search on page 24
For a description of each key on the remote control refer to the Key
Descriptions section
If your component s brand isn t listed in the Code List or you have tried all of the codes for your brand and
the remote does not operate your component use one of the Code Search methods below Manual Code
Search or Auto Code Search. Both Code Search methods search all of the codes because your component s
code may be listed under another brand in the code list.
Note The Code Search method may take a long time because the remote searches all of the codes in its
memory for the code which operates your component. Therefore, if your brand is listed in the Code List
use the Direct Entry method described Manual Code Search
1 Turn on the component you want the remote to operate.
2 Press and hold the CODE SEARCH key until the indicator
light illuminates. Then release the CODE SEARCH key.
3 Press and release the component key that corresponds to the
component you want the remote to operate TV
indicator light blinks once and then
remains lit
4 Aim the remote at the component and press the ON OFF key
continuously until the component turns off
Important Because there are so many codes, you may have
to press the ON OFF key many times possibly up to
200 times.
5 When the component turns off press the ENTER key to store
the code
6 Use Code Retrieval on the next page to identify the code for
your component for future reference
Nov 05, 2011 | RCA RCU403 Remote Control
Is there a universal remote that will work on hisense model HYDF-EP209C1
Hello
Just buy one [ PHILIPS CL 034 ] model universal remote control. Your Hisnse TV is listed in its codes. Codes and proceedings are given below:
0908 0819 0223
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
OK.
Jan 24, 2011 | Hisense TA42P40M 42 in. Plasma Television
Remote control for konka K2979
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your TV, Konka is listed in its codes. The codes and entering procedure are given:-
Codes For Konka:-
0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK.
Dec 15, 2010 | Konka Televison & Video
Free list of codes for a magnavox mru3300
I'm not positive but these codes should work, if not try the CODE SEARCH function. I'll post the Code Search instructions first, then I'll post the Brand Codes (list is a bit long so it might take a couple of posts). Let me know if any of this helps you and I'll continue to search for a pdf type of code list for the mru3300 for you.
*CODE SEARCH
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Dec 13, 2009 | Philips Televison & Video
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
Need code for a dynex tv
The code for the dynex is not listed you will have to do a search:
be controlled.
button.
Note, pressing “0” performs a full
Code Search Method.
the code.
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
button.
channel. The red indicator blinks,
then stays lit.
the code.
Most users will want to store VCR
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
Entry. Then follow the steps above for
Brand Search or Complete Search.
Jan 12, 2009 | Philips PM3S Remote Control
Want code to run sharp mini shelf system
Try searching for your code. If it is not listed in the manual. Here are the instructions to search for your codes:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Here is your manual:
http://www.ofausa.com/remote_manual/CTGA...
If the code search funtion does not work you may need to purchase a diffent brand of universal remote.
Dec 02, 2007 | One For All URC-3021 Remote Control
Postal Code search?
Here's the quote from the Nuvi 350 Users Manual:
Quote 1 (page 7):
"You can search for a postal code. Enter the postal code instead of the city name."
Quote 2 (page 7):
"2. Select the region, city or postal code, when prompted.
Note: There never appears to be an occasion when I'm prompted to specifically enter a postal code, just a city. So I naturally do as instructed in quote 1 above.
Ideas?
cantfigger
Oct 14, 2007 | Garmin nuvi 350 GPS Receiver
One For All URC 8780 Remote Control Logo
12 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
