Question about Garden
Cub Cadet mower starts but blades will not turn on. Checked the ground wire it was ok. Also replaced PTO switch that was not the problem. Any suggestions?
Mower runs great, but as soon as PTO is engaged engine shuts off? Any ideas?
  • 1 more comment
  • attila54 May 19, 2009
    The engine runs great...starts on whim....I can run around the block all day with...just cant cut grass! As soon as I engage the PTO, the engine cuts off with a whoosh.
    Do you think anything is wrong with the PTO itself? Since the carbeurator isnt covered by the warranty, I was really hoping it was!...The dealer specificaaly told me that the carb is NOT covered.
    Thanks! You are great!
  • 355 Answers
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens,
Posted on May 19, 2009
  • Rohit  Asthana
    Rohit Asthana May 19, 2009
    I think nothing is wrong with PTO...
  • 749 Answers
Check to see if there is any mosture in the engine, let it dry for a few weeks, check the spart plugs.
Posted on May 18, 2009
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
Pto will not disengage
first unplug the switch and see if it still operate then disconnect the spark plugs then turn the blades threw the discharge opening and see if the engine rotates when moving the blades this will tell you if the clutch is stuck then connect the spark plug wires back on and next to the engine base you will find a 2 wire connector that feeds the clutch power and ground unplug that connector and start the mower see if the blades turn this will tell you if you have a mechanical failure if it does not operate with the wires unplugged its a electrical
Jun 13, 2012 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
Apr 28, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
I have a cub cadet RZT 54 that was purchased in the spring of 2009. The mower cranks and runs fine but the blades will not engage. Have looked at electrical connections and everything looks fine.
Do you hear a "clunk" when you engage the PTO switch, but the blades don't turn? If so, then check the mower deck belt - is it properly threaded, and tensioned by the idler pulley? If there's absolutely no sound when you engage the PTO switch, the problem is likely electrical (even though everything looks OK). The PTO switch, PTO clutch, and the reverse lockout switches (near the bottom of the fwd/reverse control arms) should be checked. I don't think there's a separate fuse for the PTO on your mower, but there may be a relay. Even though these parts and connections look OK, they can fail internally. Best bet is to get a multitester and check each of them with the ohmmeter function.
Jul 02, 2010 | Cub Cadet Garden
Cub cadet z54 will no start
one of the safety switches are bad it could be the seat are the clutch are the blade switch you can try jumping a wire to the posts after you unplug them one at a time
Jun 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Chances are your blades are activated by a vacuum system. Often times that vacuum switch goes bad and has to be replaced.
Apr 16, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
